Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: M2-ATX shutdown question
  1. #21
    Aug 2002
    Eau Claire, Wi
    any update on this? I am also working on a system with an nLited XP install. My power buton will not shut down xp and i have no options for it in power settings. Any idea what nLite may have removed to cause this to happen?
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
  2. #22
    Constant Bitrate trance728's Avatar
    Mar 2005
    Huntington Beach, CA
    im having almost the same problem, boots up fine but does not shutdown. the wire that i connect to the j8 terminal works fine, if i hold it together it will shut down the computer. i had this previously installed in my car with an m1-atx and it worked like its supposed to, but now with my reinstall im not sure whats going on with it. another wierd thing is if i do the jumpers on everyone but B, it doesnt start up on ignition.
  3. #23
    Low Bitrate enhanced08's Avatar
    Jun 2006
    McHenry MD
    I think I know how to fix the shutdown part of it with nLite, when you get to the screen where you type the cd key and such there is a dropdown menu for the "pc type" or something similar, click the "?" to help ya decide which computer you have, you need the one with ACPI for it to work right. I did this and reinstalled and now the system shutsdown all the way when shutdown is selected.
    I still havnt been able to get the system to shutdown when the key is turned off tho, it turns on but not off via the key...
  4. #24
    Apr 2006
    I attempted these solutions because my M2 was acting like a standard PSU. The only test I could not do was the continuity test because, I'll be honest, I have no idea how to go about doing that. After switching polarity, I can no longer get the pc to start up (no fans, nothing) I know that I at least have 5v power because I was able to observe the leds on the front of the case as being on. Swapping back to my M1 psu did not fix anything. Any advice would be much appreciated.
    **edit Turns out I am an idiot and had the front panel pin out wrong. Now to just see about getting the M2 to perform an intelligent shut down, as opposed to a hard cut off. **
    **final edit...I really should pay more attention to wires when I unplug them....all works well now**
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. Another M2 ATX Problem
    By mattfl in forum Power Supplies
    Last Post: 02-23-2006, 05:47 PM
  3. question involving shutdown?
    By ralphyboy1 in forum General MP3Car Discussion
    Last Post: 04-26-2005, 01:47 AM
  4. dumb question about regular atx power supplies.
    By acura cl in forum Power Supplies
    Last Post: 04-17-2005, 12:44 PM
  5. UPS / Auto shutdown question
    By gizmomkr in forum General Hardware Discussion
    Last Post: 05-22-2001, 03:33 AM
