We might be starting to communicate
Basically the THING should connect the HOT to the ACC for the M1 when it gets an ACC signal, then after a period of time no longer connect the HOT to ACC. From that point if the ACC is high, the computer stays on, but if the ACC is not high, then the M1 can begin it's own shutdown proceedure.
I wanted to go that route since if I have to lock the car from a distance, the dome light comes on automatically and I did not want the computer to come on and stay on.
Looking on the net I found a circuit that might work ... I redid it a bit and included it below. It seems to use the resistor and cap to supply a reserve bit of
power to transistor that switches on the relay coil. Once the ACC goes low, the RC reserve power dissapates after a set period of time, the transistor turns off, the coil deactivates and turns off the connection.
The only downside to this is:
1) Would delay all shutdowns ....
2) Uses a 2N2700 MOSFET transistor .... the only ones I could find were 2N2222 which I think uses more power and might not work.
Upside is:
1) Small (would fir on my little internal board)
2) Easy to implement.
If you or anyone here has an idea to improve it, suggestions or alternate part ideas .... I'm ready for any input!
I am a bit concernes since the drawing may be wrong .. it seems to show the D and S lines both tied to ground ... would this work ????
Thanks!
... Mike ...
[Possible THING circuit below]
