Results 1 to 3 of 3
Thread: M2-ATX - Problems Starting Up
    Jan 2006
    Arkansas
    Hey all,
    I have been running the same setup since May of this year...
    Recently, I was leaving work, went to start the car and the PC never started... I thought it was odd, came home, and checked over all of the wiring... Nothing disconnected, nothing out of place...
    I turned the ignition on and pulled off the remote lead from the M2 to the CPU and low-and-behold the PC turns on... I replace the remote lead and the PC shuts off...
    I give it a few moments, turn the ignition back on and nothing... Ignition on and remove the remote lead and it starts up again, and runs fine.
    My problem is, I can't get it to turn on or run with the remote lead connected. I have not made any hardware or software changes in a few months. When the remote lead is connected and I turn the ignition on, the mobo light does light up to show me there is power, just doesn't kick on.
    Any ideas?
    Jim
    2012 Honda Pilot (In Progress)
    2010 Honda Accord (After the Pilot)
    2008 Honda VTX1800N
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by xbi0s View Post
    Hey all,
    Any ideas?
    Sounds like something happened to the M2, like perhaps the transister/relay that "closes" the startup/shutdown button isn't opening. That, or the M2 shifted, and those pins are not grounded, causing the MB to think the button is permanently pressed, or perhaps, a little piece of metal somehow got in there, and is shorting the connector. If there is no physial problem (like gorunding) then the unit may have gone bad.
    Michael
    Jan 2006
    Arkansas
    boo :-\
    Jim
    2008 Honda VTX1800N
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. Problem m2 atx and 3.5" hard drive
    By Mitski's Rider in forum Power Supplies
    Last Post: 10-05-2006, 12:52 PM
  3. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  4. fs: mastero mk-3.5 120w atx dc-dc power supply
    By infinkc in forum Classified Archive
    Last Post: 05-16-2004, 07:06 PM
  5. atx supply problems
    By oddcomp in forum Power Supplies
    Last Post: 10-21-2002, 11:05 PM
