Results 1 to 6 of 6
Thread: M2-ATX Wiring question
    Newbie ratboy's Avatar
    Nov 2006
    Northants England
    Hi guys,
    I've just received my new shiny M2-ATX for use in my first car PC project and I have a quick question about wiring that someone may be able to help with;
    I'm going to run the +12 and 0V lines straight off the battery (with a fuse in-line) but I'm in two minds as to where to attach the switched (ignition) live, I don't want to do any damage to the fusebox as the car is under warrenty and in the past I've just bummed off the ignition line that my Pioneer head unit plugs into, but I don't want to overload the power draw on that line.
    I guess what the question boils down to is; how much of a draw is there on the ignition line to the headunit? Or is it purely used as a signal line by the M2-ATX?
    Cheers!!!
    The Mighty Rat.
    Peugeot 206 Hdi
    Pioneer AVH-P5700DVD
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    It is used purely as a signal. Tap into whatever is most convenient and don't worry about power draw.
    ~Jimmy
    Elsewhere
    Check out http://www.the12volt.com
    Find a wiring diagram for your make/model of vehicle.
    Determine a device that's controlled by the ignition.
    Tap into the power for that device.
    Some common places to tap into IGN-controlled 12v:
    Cigarette lighter, headunit, power windows or sunroof
    There is almost no draw on the IGN0-controlled line. It's just used as a sense line.
    How about the Wiki?
    Nov 2006
    Northants England
    Brilliant Advice guys!
    I'll post tomorrow to let you know how it goes.
    The meek may inherit the Earth but the Rat's will inherit the meek.
    Dec 2006
    Kirkuk, Iraq
    so where did u put it?
    Nov 2006
    Northants England
    Sorry, been globe-trotting, I ran it off the ACC behind the head unit, having a few problems though as the ECU in my car likes to turn on the ACC line for no apparent reason, even when I'm not in the car, thinking possibly a problem with my headunit.
    I only found out because the CarPC booted me off of MSN messanger when it logged in over Wi-Fi from the parking lot outside my place.
    So I'm gonna stick a toggle switch in the ACC feed to the power supply, that way I can kill it whenever and make sure I don't come back to a dead battery.
  1. amp input wiring question
    By rlee02135 in forum Car Audio
    Last Post: 07-27-2006, 01:58 PM
  2. Replies: 32
    Last Post: 10-13-2005, 01:05 AM
  3. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  4. Replies: 7
    Last Post: 06-27-2005, 10:45 PM
  5. Wiring Question (long)
    By mtmsol in forum General Hardware Discussion
    Last Post: 05-18-2001, 10:39 AM
