+ Reply to Thread
Results 11 to 20 of 24
Thread: 5v DC power supply for us heavy USB laptop users..
  1. #11
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    welp talked to my friend who has bought their 5amp unit. Apparantly it puts out tons of heat when in use and stays quite hot.
    I would nmot reccomend them for anyone using them in tight confined places without actual fan cooling. Looks like I'll be getting the carnetix, if I need more amperage I can always buy two.
    edit : UPDATE
    got to check out my buddies rig, he drives a flatbed truck and has two units installed. a 12v and a 5v. Both got fairly hot (over 50c at least, opertating temperature is only a max of 60c...) This was with a bunch of usb devices all on. Both were installed under his passenger seat so plenty of air space but no extra cooling. If you get a meanwell consider fan cooling for best usage.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  2. #12
    Jul 2005
    USD39 for a 12V-4.2A out 9-18V in :
    http://www.trcelectronics.com/Meanwell/sd-50a-12.shtml
  3. #13
    Low Bitrate GibsonLP's Avatar
    Mar 2005
    Israel
    2 questions:
    1. Do you think I can put the 5vdc 5A unit in the trunk without using a fan? (however - it's in the trunk, not such a confined space).
    2. In practice - how do I hook up such a unit to my units? what about units that have no power supply input, just usb input? can I just "power" my entire usb network with this unit?
    Thanks.
    Edit:
    What do you say about this converter -
    http://store.altenergystore.com/Char...nverter/p1302/
    Looks pretty efficient (but expensive...)
  4. #14
    Sep 2006
    Georgia
    Quote Originally Posted by GibsonLP View Post
    2 questions:
    Thanks.
    Edit:
    Nice find but yes very very expensive for only 5 amps. You could get 2 carnetix 5v POL's for $50 and end up with working amps.
    1: As for the meanwell. Mounting in the trunk should be fine. but I'm not going to risk it. The psu is going to be enclosed with my laptop underneath a panel of wood. I am going to be using fans to circulate air in and out of the enclosure but not alot of them. After feeling how hot the meanwell got I wouldn't reccomend using it any tight enclosed areas. If you mounted it to the widewall or top deck of the trunk then it should be fine. but behind carpet would be a no no.
    2: You can either splice the cable. Buy a USB dual head cable and splice into the extra connector. Or just use one of these devices to power a USB hub. That way all your devices get max power. Remember at most a usb device used 500mA And thats only the high end stuff. Very few items surpass that (some usb drives) To overcome that they almost always include a secondary input jack. But everything else generally gets its power off the usb bus so a powered usb hub is the win.
  5. #15
    sigh i wish i would have read thoroughly before i ordered. im in the process of installing mine. i think overloading my p5v was causing instability of my computer system. I wanted something inexpensive to supplement the p5v so i bought the 10 amp system listed above. the main thing that worries me is that this will be under a floor with many other hot devices, such as amplifiers and my carputer.
    anyone know what i can do to make this work out?
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  6. #16
    Mar 2004
    New Jersey
    Quote Originally Posted by miztahsparklez View Post
    Mine has been buried under my trunk carpet for months now.. i have had no problems at all.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
  7. #17
    sounds good then. I noticed that there seems to be two grounds on the device. How did you hook yours up? specifically, what did you do with the connection that has the ground symbol on it?
  8. #18
    Mar 2004
    New Jersey
    the one with the ground symbol i grounded to the frame of the car, the (-) i hooked up to the gnd of all the 5v devices.
    -Jack
  9. #19
    but theres also the ground input too. so mine has a total of 3 grounds.. one to the 5v. and the other one to the car. but im unsure of the third.
  10. #20
    Mar 2004
    New Jersey
    I looked again today. I connected the gnd logo and the ground for the 12v together
    -Jack
+ Reply to Thread
  1. dc - dc power supply vs. an inverter
    By deepdivered in forum Newbie
    Last Post: 01-05-2006, 10:42 AM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. DC DC power supply
    By modh1984 in forum Power Supplies
    Last Post: 11-23-2005, 01:56 PM
  4. Replies: 14
    Last Post: 02-11-2005, 07:35 PM
