Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 5v DC power supply for us heavy USB laptop users..
    Mar 2004
    New Jersey
    http://www.trcelectronics.com/Meanwell/sd-50a-5.shtml
    About $40 dollars and this will power up to 10amps @ 5 volts. They also have smaller versions but this gives you the most bang for the buck. Most of you may use your computer power supply but this is more of a solution for us laptop users who dont have a large power supply to start with.
    It takes 9.8 to 18 volts input and regulates it to 5v output. 70% eff rating
    Why 10 amps? Why not? Think of it:
    2~3 amps for DVD-R drive
    500mA for Wifi
    250mA for Bluetooth
    100mA for Shuttle express
    500mA for HQCT
    400mA for XM PCR
    100mA for Touchscreen
    50mA for mini usb keyboard
    500mA for sound card (if usb)
    Thats almost 7 amps!
    1 powersupply to power all your usb hubs and your hqct and external DVD drive. I have used this for about 2 weeks now and everything runs great.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    Elsewhere
    Excellent find!
    How about the Wiki?
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    more specs
    http://www.trcelectronics.com/Meanwell/pdf/sd50.pdf
    Ripple & Noise 100mVp-p
    Rated Power 50W
    Voltage Tolerance +-2.0%
    Line Regulation +-0.5%
    Load Regulation +-0.5%
    Efficiency 70%
    Overload Protection 105 ~ 150% Rated output power, Fold back current limited protection
    Over Voltage 5.75 ~ 6.75V /10% Load, Hiccup recovery
    Working Temp -10 ~ 60Degrees Celcius, 20-90% Humidity
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    I, and a couple of other people here, use the 12v one. There are 15W, 25W, and 50W models. These are just DC-DC converters -- there is no SDC.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Sep 2006
    Georgia
    I was heavily considering this one but the 70% efficiancy rating worried me. I'd rather not have a component that wastes so much power making heat. Just a thought for anyone who might want one
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Mar 2006
    Colorado, but Canadian!
    70% really isnt too bad for cheap regulators. As long as you dont put it in a confined space, it should be fine
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2006
    Georgia
    Quote Originally Posted by 2k1Toaster View Post
    oh it would definitel be in a confined space. which is why im staying away
    I love the fact that it has a it's own casing. Easy install with screw down terminals. But the heat man, the HEAT!
    Jul 2005
    cosel is much too expensive !!!
    Sep 2006
    Georgia
    Quote Originally Posted by raxy View Post
    Not really. You would have to buy 3 carnetix 5v POL units to get 9amps, this unit does 10 amps for only double the price of the carnetix(Actually less than double)
    but alot of that will be wasted putting out heat.
    Sep 2006
    Georgia
    they also have a 3amp 15watt 5v POL
    http://www.trcelectronics.com/Meanwell/psd-15a-05.shtml
    again lower efficiency but more components.
    Enclosed
    http://www.trcelectronics.com/Meanwell/sd-15a-05.shtml
    5amp enclosed $32
    http://www.trcelectronics.com/Meanwell/sd-25a-5.shtml
  1. dc - dc power supply vs. an inverter
    By deepdivered in forum Newbie
    Last Post: 01-05-2006, 10:42 AM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. DC DC power supply
    By modh1984 in forum Power Supplies
    Last Post: 11-23-2005, 01:56 PM
  4. Replies: 14
    Last Post: 02-11-2005, 07:35 PM
