Results 1 to 9 of 9
Thread: Powering 2 monitors
    Mar 2006
    Boston, Ma Area
    Powering 2 monitors
    I'd was wondering if I'd like to add 2 monitors for me rear seats connected via svideo to my computer. I would just add a DC-DC Regulator and set them both to 12v or different depending on the voltage of the monitor? So it would be battery, another fuse, dc-dc reg, 2 monitors? And whatever guage the power requirement would be?
    "The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
    Dam it!
    "The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
    Mar 2006
    Boston, Ma Area
    I was looking at this.
    http://store.mp3car.com/ProductDetai...Code=PWR%2D010
    I think the monitors use 9-12 volts for power source. Now the carnetix p1900 as 1 outputs one with +18/+19/+20V and another with +12V/+13.5V or +5V.
    Can I connect a monitor to the +18v on the carnetix or will it send a power surge to my monitor and blow it? And I'm assuming the 12v will work fine for the second monitor.
    Dam it!
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    ViViper, I would simply attach Molex connectors daisy-chained onto the 12V rail of the carnetix. The 12V rail should be more then sufficient to handle two monitors as most monitors only consume .5-1.0 Amps. That is not too serious of a draw and you will have the monitors switched off automatically when the supply is off. Although, many monitors nowadays come equipped with sufficient voltage regulation/protection and shut off when there is no video source detected. Hope this input helps.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Mar 2006
    Boston, Ma Area
    Quote Originally Posted by Eternalodyssey View Post
    Sorry haven't had the internet for the last few days and it's been driving my crazy because I'm having trouble setting up the pc . How do I attach Molex connectors daisy-chained onto the 12V rail of the carnetix? I don't quite understand this part.
    Dam it!
    Elsewhere
    Quote Originally Posted by ViViper1 View Post
    The molex is a generic term that refers to the 4-pin HDD power connector. (Technically Molex is a brand of those style connectors)
    There are 4 wires in teh molex: Red, Black, Black, Yellow.
    Yellow = 12v
    Black = Ground
    Black = Ground
    Red = 5v
    You would simply need a male HDD power connector (the ones from the power supply are female) and wire the power lines from your screens into the 12v and ground pins.
    How about the Wiki?
    Mar 2006
    Boston, Ma Area
    Quote Originally Posted by DarquePervert View Post
    Yellow = 12v
    Black = Ground
    Black = Ground
    Red = 5v
    So I would have to buy this
    http://www.crazypc.com/products/PQ4-53901.html
    and then cut the power cable for the monitor, btw which one is positive and negative on the lilliput monitors? Solid Black or solid black with a white stripe.
    Somehow run it into these male connectors. But it would be 2 positives into the 12v, and 2 monitor grounds into 1 ground or both?
    Then on the carnetix box I would connect the 2 wires for the 20v output to a female molex? 1 wire going into the ground? And voila plug and watch it work?
    I don't know much about electronics, but I was wondering why can't I just wrap the 2 positive wires and 2 ground wires straight to the wires that come out of the carnetix? Sorry by wrap I mean wrap the ends, not sure the term.
    Dam it!
    Elsewhere
    I'd purchase something like this: http://store.mycableshop.com/itemdes...PUFANADAPT.htm rather than just the pins.
    Even better: http://www.action-electronics.com/molex.htm#Amp
    Yes you could splice into the wires, but I think it's a better idea to wire up a compatible connector. That leaves your wiring harness for the PSU intact, so you can more easily sell it later on down the road, disconnect devices for troubleshooting, etc.
    How about the Wiki?
    Oct 2005
    St. Louis, MO
    Your best bet is to simply use an in-line crimp connector and then cut apart the molex connector to crimp the wires together. The crimp connector looks like a tube and has metal inside it. Simply cut the yellow wire and the ground wires and then strip a small bit to expose some of the conductor. Then crimp the wires to connect them to your power source and your ground. This way you have a removable power connection. I am working on mine today and I can shoot over some pictures here in a little while. Also, your power wire on your monitor is going to be the solid wire WITHOUT the stripe. The ground wire is the wire WITH a stripe going down the side.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/showthread.php?t=85490
    Mar 2006
    Boston, Ma Area
    Dam it!
  1. Smart question regarding headrest monitors
    By vinzer in forum LCD/Display
    Last Post: 09-11-2006, 10:00 PM
  2. 15" monitors and vga splitter
    By jesse13579 in forum Classified Archive
    Last Post: 06-19-2006, 01:19 PM
  3. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 02:15 PM
  4. What size / resolution headrest monitors?
    By jedi7001 in forum General Hardware Discussion
    Last Post: 03-13-2005, 10:42 AM
  5. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 02:46 PM
