Results 1 to 8 of 8
Thread: Will the Power Inverter be enough?
    Nov 2005
    My computer has been running fine in my car but lately I've been getting the urge to add a few things. First I'm adding an external DVD enclosure that runs off of USB. I also added a wireless internet adapter and a wireless keyboard w/ mouse that both run off of USB. I'm sure I'm very limited with what my power supply can dish out to "USB".
    I'm using an M1-ATX. My question is though, I'm going to be adding a power inverter to power a PS2 and I was wondering if I could just get a USB hub that plugs into AC power like the inverter. Then I could run most of the USB devices off of the hub and not the power supply in the computer. Would that work? Darque mentioned adding a POL, but if I'm already getting an inverter wouldn't that work as well?
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    This can certainly work. Just make sure the Inverter is powerful enough to handle everything you need... My suggestion is you add up the power requirements of all the devices and then get an inverter with more power than that. This way, in the future, you won't experience the same issue you're having now with expandability.
    -Jon
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Nov 2005
    Is there a way to calculate the power each USB device is needing? Like I'm looking at my drive that came in and it doesn't say anywhere how much power it consumes.
    Apr 2005
    NJ
    Hey kbkid,
    I looked for a minute or two and this is what I was able to come up with.
    http://www.epiacenter.com/powersim/p...mulator_v2.htm
    hope it helps
    -Jon
    Hello! VW Golf 1.8t
    Nov 2005
    Yeah as soon as I posted I found that as well. It doesn't make much sense though. I have a Via M10000 MB, a 2.5 harddrive, a single slim line DVD drive, then I have a wireless adapter for internet, wireless keyboard, touchscreen, an external DVD drive that takes two USB ports and I had planned on getting GPS reciever. So thats 6 USB devices. That is giving me a 41.16 watts? Is that right? My video and sound are both coming from the onboard motherboard.
    Also that is all at idle. If I were to be running Mp3s it would be 47.25 watts. That just doesn't seem like much.
    Apr 2005
    NJ
    I would assume its correct, but some others may have actual data if you look around for it. I personally don't have a Via board so I can't tell you. but I'm sure someone will come around to help if you ask the right question.
    Hello! VW Golf 1.8t
    Nov 2005
    Alright I'm assuming a 400 watt inverter would be plenty to just power the USB hub, wouldn't you?
    Nov 2005
    The USB hub I am thinking about picking up is the D-Link DUB-H7. It appears on the back of the hub, it has a Type B USB port and a power port. The power port says 5V 3A. Can anyone explain this to me. Does that mean the "power adapter" plugs into the wall, as in 120V, like a household outlet. I know this sounds pretty stupid but it doesn't make sense.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Inverter Power Question
    By SniperXX in forum Newbie
    Last Post: 06-13-2005, 09:51 AM
  3. Replies: 5
    Last Post: 02-04-2005, 10:07 AM
  4. FS: VECTOR MAXX 700 Power Inverter
    By muldrick in forum Classified Archive
    Last Post: 10-23-2004, 08:41 PM
  5. UPS power backup as inverter?
    By CA 3000GT in forum Power Supplies
    Last Post: 02-13-2003, 01:52 PM
