Results 1 to 10 of 17
Thread: Head unit ignition cable.
    Newbie D4niel's Avatar
    Aug 2006
    Essex
    I am not really happy in cutting the ignition cable which i am yet to find on the car. Can i run the ignition cable from the car pc to the one which runs to the headunit. Both cables are yellow?
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    I don't like the term ignition cable makes me think of the big wire going to the starter, I much prefer Accessory(ACC). This emplies it is on ( 12v ) when the key is in the run position.
    The ACC connection to your head unit could be tapped.
    You could also run the psu off of the Headunit remote signal.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    or tap the acc line at the fuse box.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by D4niel View Post
    Don't fall into that trap. In automative applications never rely on the colour of the wire to tell you what it's carrying/what it does.
    But yes, you can use the switched ACC (accesories) wire as the switched ignition line to your psu
    Aug 2006
    Essex
    Thanks for the quick reply, anther question answered. Now i can get the new mac mini 1.66ghz dual core w/512mb ram and 60gb hd, very cheap. What power supply can i use for this? I have seen the inside of the case and it doesnt appear to have a standard atx connector, infact it doesnt appear to have any internal power connector. Any ideas?
    Nov 2006
    i have had an idea i dont know if this will work or how to realy cary it out
    my idea is to run a lead of the + side of the alternater to turn on my mechanicle touch screen to make it eject witch then in turn will complete a cyercit to make my pc come out of highbanation then inturn turn the amp on
    i thoght the alternater as it will only give live out when engine is runing also i thoght it would look cool but if any one can think of a better way of doing this pls let me know
    Elsewhere
    Not a good idea. The alternator's job isn't to power any devices, but to charge the battery. If you draw power directly from the alternator, it's less power going to charge the battery.
    Tapping into the fuse block is a good idea.
    Tapping into existing wires that provide ignition-controlled power is another great idea.
    Having an extra wire running from your alternator will not look cool. It will look like you don't know what you're doing.
    How about the Wiki?
    Nov 2006
    well considering u have a wire that goes to the dash from alternator anyway and it would only run to a realy so not takeing really any voltage and most alternator's have more the 1 live terminal last car i worked one had 1 earth 2 heavy load concetsr and one low current cable that runs to dash to a volt meter dont think it will matter to mutch only thing i ant sure on s how i could make a it come on then click off as the lcd would keep operning and closing cos of cycit been complete all the time
    Nov 2006
    i do apaolergise for my spelling and such but i am badly diclexic
    Nov 2006
    Mate,
    Rather than all that fiddling around, you're better off just running it off the switched 'acc' or 'on' key positions. Running a wire from the alternator isn't a great idea not only becuase of what the Super mod said, but the alternator only charges when it needs to. When the alternator has charged the system to a pre-determined level, it stops charging.
    If you run your carpc on this output from the alternator, it's going to be turning on and off all the time in time with the alternator starting and stopping charging.
    I installed my carpc into my pet Kangaroo, mate.
  1. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 10:24 PM
  2. Software to allow head unit to control winamp?
    By gabeknuth in forum Software & Software Development
    Last Post: 09-19-2006, 09:57 PM
  3. New Head Unit Recommandation
    By shamel in forum Car Audio
    Last Post: 09-14-2006, 01:19 PM
  4. Renault Head Unit Connections
    By cupax in forum Hardware Development
    Last Post: 08-16-2006, 06:23 AM
  5. Replies: 3
    Last Post: 03-21-2005, 11:56 AM
