I think you're likely drawing too much power for the M2ATX.
It would all depend on the core fo the Athlon64 you're using.
If it's the Winchester or Venice cores, you should be golden.
However, if its the Sledgehammer or Newcastle cores, you're definitely pushing the limits.
LinkBack URL
About LinkBacks
, I think you are taxing the PS by drawing too much power. And before you say, I am under 160 watts, are you under the wattage for each WIRE/Voltage Rail. See, the M2 has 8 amps on 12 volts. You might need 20 amps (this is hyposthetical to prove the point) on the 12 volt line, though, you don't use any other voltages. So, you are under the 160 "max", but you are over the max available on the 12 volt rail.
