Results 1 to 4 of 4
Thread: Adjusting the targus pa350 universal DC Power Supply
    Variable Bitrate miwise's Avatar
    Sep 2006
    How do I adjust the output voltage on a targus pa350 universal dc power supply? I cut the end off to try to hard wire it to a barrel connector that my laptop will accept, but it now only puts out 16 volts. I need 9.5 volts. It seems to have 4 wires (one ground, one positive, and two other smaller wires I assume to be the selectors for the voltage). I think it may sense resistance on these smaller wires, but not sure. I don't know what makes it choose the voltage. How can I adjust the output voltage?
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    Sep 2006
    found out how to adjust the voltage! Its very easy. Just stick a resistor b/w the grey wire and ground wire. I used a 10k and 5k to make 15k. This got me 10 volts. The greater the resistance, the greater the voltage setting. I'm going to get some lower impedence resistors to try and get a consistent 9.5 volts. I'm also going to get a better voltometer b/c mine is messed up and reads about 2 volts off.
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    ftl
    ftl is offline
    Dec 2008
    Targus PA350 Voltage Adjust
    Hi I found this thread when I was looking for information on how to set the output voltage on my recently acquired (for free) PA350. I found some other information on the web and did some testing and came up with the following. This includes data from my own testing and a few posts I've copied from elsewhere to consolidate the information here.
    I hope this is useful to somebody.
    Code:
    Setting the output voltage of a Targus PA350:
    The following data comes from testing of my PA350.
    The back of my unit is labeled with:
        "PA350(Ver. 2.0) E0801"
    Looking at the plug on the end of the cord:
    | 1   2   3   4  |
    | ?   +   -  Set |
    1 - Red    - Unknown purpose
      - Maybe current limit. Connected internally to something.
        Setting resistors to pin 2 or 3 has no effect on output voltage.
        On my one tip (#24) this is not connected.
    2 - Yellow - Output Positive
    3 - Shield - Output Negative
    4 - Grey   - Voltage Set - See resistor table below.
    The output voltage can be set by placing a single resistor between the
    Grey wire (pin 4) and either the negative or positive output wires as
    shown below. I got this data by testing my unit with an assortment
    of resistors (most were 5%, but some were 1%).
    Output    Grey to   Grey to
    Voltage   Negative  Positive
     2.8        2.2K *
     3.3        2.7K
     5.1        4.75K
     8.0       10K
     9.7       15K
    11.7       27K
    12.3       33K
    13.3       47K
    13.7       56K
    14.0       68K
    14.3       82K
    14.7      100K
    14.9      120K
    15.1      150K
    15.4      220K
    15.7      330K
    15.8      560K
    16.0        1.0M
    16.1        3.3M
    16.1      open       open
    16.2                   3.3M
    16.5                   1.0M
    16.8                 560K
    17.3                 330K
    17.9                 220K
    18.9                 150K
    19.6                 122K  (Resistor in #24 tip)
    19.7                 120K
    20.7                 100K
    22.0                  82K
    23.8                  68K
    26.4                  56K **
    * - The output went to 2.8V, and it seems to work, but the pilot light
        went out with this resistor. This is less than the unit's 3.0V minumum
        rated output voltage.
    **- With a resistor less than 68K from grey to positive the unit would
        shut down and set its output voltage to about 2.0V. It is necessary
        to remove the input power to get it to reset. With a 56K it would
        shut down when the resistor was applied, but would work when the
        power was re-applied. I did not try it under load with this resistor
        so I do not know what would happen in that case. This is beyond its rated
        output of 24V.
    Targus Power Tips voltage by Tip Number
    - From a posting at 1-script.com by Barry Watzman
    1 - +16.00 volts
    3 - +18.00 volts
    4 - +12.00 volts
    6 - +15.00 volts
    7 - +16.50 volts
    8 - + 8.40 volts
    5 - -12.00 volts (tip negative)
    10 - + 2.95 volts
    11 - + 6.00 volts
    12 - +10.00 volts
    15 - -10.60 volts (tip negative)
    16 - + 5.50 volts (wide variation)
    17 - + 8.50 volts
    18 - + 9.40 volts (wide variation)
    19 - +16.60 volts
    20 - +13.00 volts
    21 - +19.00 volts
    24 - +19.55 volts
    25 - +18.25 volts
    26 - +19.50 volts
    27 - +15.00 volts
    28 - +22.00 volts
    34 - + 7.00 volts
    36 - +18.26 volts
    38 - +24.00 volts
    44 - +18.90 volts
    47 - +13.00 volts
    48 - +18.20 volts
    57 - + 4.10 volts (wide variation)
    58 - +20.00 volts
    74 - +16.00 volts (wide variation)
    Posting from somewhere else (I didn't record the specifics):
    Tip #24 [with one caveat, see below] will power the Toshiba Satellite
    A105 (nominally the A105-S2712 takes 19 volts at up to 3.42 amps).
    This also suggests that tip #24 will work with the A80, A85, L10, L15,
    L20, L25, M30X, M35X, M40-S312TD, M45-S165 , M45-S165X, M55-S139,
    M55-S139X, Tecra L2 and Tecra M2, since they all use the same Toshiba AC
    power supply (PA3467U). [and it is therefore very likely that it will
    work with additional models that use a different power supply but the
    same voltage]
    The measured voltage under an admittedly low dummy load (a 100 ohm
    10-watt resistor) was 19.2 to 19.3 volts, 1% to 2% high and well within
    any reasonable tolerance. The voltage would probably drop a tad under
    the much larger full load of the laptop, but a 100 ohm load will draw
    200ma, which should be enough to bring the power supply into proper full
    regulation mode. [And if anyone is wondering, yes, after my testing I
    actually did run the laptop itself from the #24 tip with no problems,
    but I cannot easily measure the voltage while the laptop is running.]
    I set the output voltage (which is adjustable from 3- 24V) with a 27k
    resistor across the sense wires. (This is between the grey and the ground to
    get 12.1 volts) When I cut off the end there are 4 wires in the cable.
    A thick yellow one, a thin red one, a thin grey one and a ground (shield).
    Apr 2002
    orlando
    I know this is only but I had to thank miwise, great post! So wanted to know how they did this as they told be I could not order my tip for my unlisted laptop. Now I can make one!!
    I should have guess that what te 2 extra wires were for..
    UMPC built in to dash.
    Winamp, game emulators, Touchpad built in to car, DVD player built in to dash, GPS gamrmin moble pc. IR remote for use of a remote control. ps2 supper mini keyboard for when needed.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. DC DC power supply
    By modh1984 in forum Power Supplies
    Last Post: 11-23-2005, 01:56 PM
  3. FS: 250 watt DC to DC Power Supply
    By EsKALad in forum Classified Archive
    Last Post: 11-11-2005, 08:58 PM
  4. Replies: 14
    Last Post: 02-11-2005, 07:35 PM
  5. Replies: 8
    Last Post: 11-04-2003, 12:03 PM
