Results 1 to 10 of 10
Thread: Which ground wire should I use or does it really matter
    Newbie Major_Disaster's Avatar
    Oct 2006
    I am in the process of ordering parts and laying out my wiring diagram. I need to ask, what on the surface appears to be a dumb question, but here goes; To power my system I will be using the 12+ as indicated in the image labeled J7, but does it matter which ground I use?
    From my limited knowledge, I could use any ground that is available or even ground to the chassis if I desire. Is this a correct statement?
    Thanks for everyone’s help. I have learned a lot “just lurking” and reading the various posts.
    Newbie MarkH's Avatar
    Feb 2005
    Reading, UK
    any of the grounds on J7 will be fine
    Newbie MaXimaN's Avatar
    Nov 2006
    London, UK
    I'm not sure I understand your question. Do you intend to power something other than the PC motherboard and hard drive from your ATX power supply? This is usually a bad idea, as the 12V line from an ATX power supply has a limited supply of current.
    Or do you mean power your entire system just from the 12V line on the ATX connector pictured?
    System:
    Jetway J7F2 2GHz C7 Mainboard
    1GB DDR2-533 RAM
    120GB Hitachi 2.5" 5400
    VoomPC case with M2-ATX PSU
    Buffalo Airstation 54G wireless with ext. antenna
    CompactFlash Bluetooth.
    Oct 2006
    Clarification on which ground wire to use:
    MaZimaN:
    Thanks for your interest. Let me clarify a bit:
    I am planning to use a DSATX (220 watts) to power my Dell SX270, an external HD (external USB enclosure with desktop 250GB HD) and external DVD ROM. I was planning to power the SX270 off the 12v rail, and the other items off the appropriate rails (to eliminate external 12 power supplies/converters).
    I wanted to have a little head room for additional items should I decide to add additional items.
    The image pictured is from the DSATX and shows which pin layout. I was curious about which ground wire to use or if it really mattered as to which ground wire was utilized.
    Quote Originally Posted by MaXimaN View Post
    Oct 2006
    re: Which ground wire should I use.....
    Thanks MarkH. Just curious if it mattered........
    Quote Originally Posted by MarkH View Post
    Nov 2006
    London, UK
    Quote Originally Posted by Major_Disaster View Post
    MaZimaN:I am planning to use a DSATX (220 watts) to power my Dell SX270, an external HD (external USB enclosure with desktop 250GB HD) and external DVD ROM. I was planning to power the SX270 off the 12v rail, and the other items off the appropriate rails (to eliminate external 12 power supplies/converters).
    Ahhh I see! In that case, it shouldn't be a problem. The SX270 stock PSU is 150W and the DSATX can cope with that on the 12V rail at a push. I'd be a little wary of powering anything more than the SX270 on the 12V rail though, especially if you intend to power the external HDD and DVDROM off the same rail. The SC270 uses an internal 2.5" drive - is it not possible to simply use that instead of your external unit?
    System:
    1GB DDR2-533 RAM
    Oct 2006
    re: powering sx270 and external accessories
    The internal drive is small.........only 20GB...that is the reason for the external drive. I just happened to have a 250GB drive sitting in the closet. I was able to pick up an external enclosure for $12 (sorry...that was the last one). I have not purchased the DVD Rom yet.
    I will ensure that everything is fused so hopefully it should not be a problem.
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    splice your molex connector, yellow = +12vdc, black=ground, black=ground, red=+5vdc
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Oct 2006
    gameboy,
    Thanks for the info..........
    Quote Originally Posted by gameboy View Post
    May 2005
    Elizabeth City, NC
    gameboy,
    np, its alot easier to use a molex connecter anyway, pick up a y-adapter for the 4-pin molex at any computer store, and splice it instead or using the one that comes with the DSATX....thats how i have my Soundblaster NX2(external) powered.....
    keep an eye on the amp consumption tho.....don't want to draw too much off any one rail. i think on the dstax you have upto 15 amps PER rail.(which is alot better then some of the other DC-DC PSUs
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Opus ignores ignition wire, constantly stays on
    By Sham-Mobile in forum Power Supplies
    Last Post: 08-26-2006, 07:28 PM
  3. ground loop problem... cant fix it
    By okeydokey in forum Car Audio
    Last Post: 06-23-2006, 09:27 AM
  4. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  5. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
