Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help using PSU to power car amplifier
    Nov 2006
    I have a 350 watts amplifier 13 amper at 12volts, i try to connect it to the amplifier but it shut down two second after I connect it.
    Why is this occurring? What I need to do to make it continue working and not shut down?
    Aug 2006
    Atlanta, Ga
    What kind of amp? And most amps use 20+ Amps of current.
    Car PC Status {------- }0%
    Car Died along with Autonode Monitor after returned to me. Worked for 3 Months then died again. The car engined died not long after!
    Upgraded to 2003 Infiniti G35 Coupe
    Exploring options of a double din unit style Car PC.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Williams16 View Post
    A PSU will NOT have enough amps to power your amp. Also, 350 watts/12 volts=30 amps. That assumed 100 percent efficiency, and it most likely is not.
    Michael
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Your amp probably also has an inrush current of 50A or more, causing your PSU to throw up short circuit protection, and shutting itself down. If it doesn't, you can be looking at an electrical fire!
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Newbie MaXimaN's Avatar
    Nov 2006
    London, UK
    Does your amp not have a remote (RMT) point?
    System:
    Jetway J7F2 2GHz C7 Mainboard
    1GB DDR2-533 RAM
    120GB Hitachi 2.5" 5400
    VoomPC case with M2-ATX PSU
    Buffalo Airstation 54G wireless with ext. antenna
    CompactFlash Bluetooth.
    Nov 2006
    Do you recomend me to take three psu and put diodes so I can get 40 ampers to power my amplifier, but A question . If I connect the PSU this way any of the PSU´s will shut down activing its circuit protection as you said. Does a PSU recognize something taking more ampers than it could offer even if the PSU are connected with diodes and creating 40 ampers?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    WHY ARE YOU TRYING TO POWER YOUR AMP WITH A PSU?
    Power the amp from the car battery/alternator. That is what it is designed for.
    Michael
    Elsewhere
    Quote Originally Posted by Wiredwrx View Post
    Power as little as absolutely necessary from the PC's power supply.
    How about the Wiki?
    Oct 2004
    NY
    man... I hope the next thread isn't "help heating my interior with my exhaust"...
    Nov 2006
    So, can I get sufficient power from PSU´s connected with diodes so the PSU´s will not shut down and activate its circuit protection?????
    Yes or NO ???????
  1. Powering car from a 13.8V power supply ok?
    By PURDooM in forum Power Supplies
    Last Post: 06-12-2006, 12:56 PM
  2. Replies: 17
    Last Post: 02-17-2006, 05:59 PM
  3. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
  4. getting power from car battery
    By [H]Bugster in forum Power Supplies
    Last Post: 11-04-2003, 10:22 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
