Results 1 to 7 of 7
Thread: Ignition wire
    Mar 2006
    Boston, Ma Area
    Ignition wire
    I am installing my carnetix, and I am a little confused about the ignition wire. Is it suppose to connect to the ignition wire or the acc wire? If so which ignition wire? Is there different wires that run into different parts of the car to turn other things like the radio on that I can tap into? Or do I have to run a wire from the steering column to the ignition wire on my carnetix?
    "The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
    Dam it!
    "The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
    Oct 2004
    NY
    if you use an accessory wire the pc will stay alive in accessory... that's best really...
    Mar 2006
    Boston, Ma Area
    Quote Originally Posted by turbocad6 View Post
    When the car is on is it still considered accessory?
    Do you know what I should do about the Dlyon?
    Dam it!
    Mar 2006
    Boston, Ma Area
    Do I just need a switched 12v source like the cig lighter or the one that powers my headunit?
    Dam it!
    Oct 2004
    NY
    the diference btween ign & accessory ... BOTH have power at run time.... an ign lead will mantain power while cranking, but loose power in acc.. an accessory wire will disconect while cranking, but obviously maintain power in accessory...
    the momentary drop while cranking of an acc lead wont be a problem with the carnetix.....
    Mar 2006
    Boston, Ma Area
    When you say momentary drop, do you mean it wont damage my carnetix and my comp wont shut off because of the hiccup in power, or it wont damage my carnetix and it will shut off my computer?
    Thanks again, new avatar?
    Dam it!
    Mar 2006
    Boston, Ma Area
    Sorry I got this post mixed up with another one. I was wondering about the Dlyon wire also. I won't be using an amp or a mac. Would I still need this cable? I looked around and heard that people use this cable to power on their devices after a certain amount of time. I was wondering how that works, does it replace the positive cable that goes into those devices or.....?
    Dam it!
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  2. extending my TS's ac adapter wire
    By skadoo323 in forum Power Supplies
    Last Post: 02-02-2006, 01:09 PM
  3. where to put ignition wire from opus 150w
    By marcus430 in forum Power Supplies
    Last Post: 01-10-2006, 03:42 PM
  4. opus 150w ignition wire
    By marcus430 in forum LCD/Display
    Last Post: 01-10-2006, 12:40 PM
  5. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
