It is not a bad idea to add more protection to anything. However, I believe any crowbar circuit will have a voltage drop, whcih could be problematic for your MB.
And while no one wants to admit it here, I believe all those broken motherboards are cases when the M2s specs are exceeded. Make sure your system is under the M2 specs, and you should be fine.
Michael
LinkBack URL
About LinkBacks
That's rather annoying to say the least! I am thinking of building a crowbar circuit on each of the rails to protect the mobo and stuff, anyone else done this? Basically a crowbar is a circuit that triggers when the voltage gets too high and shorts out that rail, thus blowing a fuse and preventing the spike getting any further. See
