I have an old XM 701 Sony power amp I want to install.
It has a trigger wire. I am locating the amplifier in the back
of my 2K Camaro and getting power from the Monsoon power
amp hidden near the spare. I connect the power cable and the
trigger wire together to the yellow switched wire on the monsoon
amp for some power but the protection circuit is on and there is
no sound. Where else should this trigger be connected. Any ideas?
1.9in x 2.9in -- 47mm x 73mm
The Monsoon system works fine but the additional amp does not produce any sound, I am connecting the second amp to the speaker outputs using a line output convertor. The powr and the red protection light turns on...so I am
stuck. Help! When I disconnected the line output convertor, the red light was still on.
but how is that amp receiving POWER?!
