Results 1 to 10 of 11
Thread: Inverter Relay Question
    Constant Bitrate thunderdepot's Avatar
    Sep 2005
    Arrow Inverter Relay Question
    Ok I am tired of turning on and off my inverter every time I get in and out of my car.
    So it is time to get get a relay to make the process automatic. I just want to double check with the great mp3car power gurus. I know nothing about electrical stuff just hardware and software. I don't want to mess anything up on my car or carputer.
    Check out the diagram below. Basically I want to leave my inverter's switch on and then use the relay to give the inverter power when acc triggers it and take away the power when I turn off my car.
    And before you tell me that inverters are terrible I know but they are the best for my dell laptop setup.
    Do I have the correct setup for what I want to do? What do you reccommend? Where should I put fuse(s)? Is 8ga wire good enough? What ga for ground and acc?
    Thanks for the help!
    SUMMER CAR:
    '96 Chevrolet Camaro Z28 LT1 Convertible
    P3 Mobile 1.2GHz/512MB RAM/Dual HD/Lilliput/Soundblaster
    XP MCE/RR/IG
    WINTER CAR:
    '02 Grand Am
    CarPC Coming Soon!
    CHECK OUT MY RR SKIN:
    RoadFuse - CF Like Day & Night Skin Combo
    Low Bitrate com2soft's Avatar
    Sep 2006
    auto start may be o.k. but when acc is off it will kill the inverter power immediately so only hard power off to the computer.
    Sep 2005
    Quote Originally Posted by com2soft View Post
    It is a laptop so I have it set so when the battery power gets to a certain level it goes into hibernation. But this is just in case I forget to use the hardwire switch that I have connected to my laptop.
    The hard wire switch will wake it up from hibernation or put it into hibernation or turn it off.
    Other than that does everything look fine?
    Jun 2006
    Chicago, IL
    I think that it requires little bit of electronics to drive the relay. Once ACC signal goes to 0V, it should give about 30sec delay before shut off, but it should send ACPI ( 5V to 0V edge) to laptop (power line) to shut it down or hibernate before the juice cuts off. Such thing can be programmed into one of processors (ATMEL, 8051, 16FXX) but it requires little electronics skills. If you basically want to cut the power off the inverter, use 12V relay, but it may corrupt some filesystems like FAT or NTFS, if you use ReiserFS or Ext3, more or less yo're just fine to do it.
    If you need any help with this problem, just PM me.
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    It would be cheaper/quicker/better to use a small relay to replace the on off switch of the inverter.
    In my setup I pulled the small wires off the switch and connected them to a $6 automotive relay from Autozone. My ACC and 12volts from the pc both energize the relay thru some 1n4004 diodes for simple isolation.
    If you want some more details let me know,.
    Sep 2005
    Quote Originally Posted by billmee View Post
    Yeah give me some more details but it sounds more complicated.
    May 2005
    USA
    Quote Originally Posted by thunderdepot View Post
    First fuse the wire as close to the battery as possible.
    Most posters will recommend 8awg wire but I used the existing 14awg cig lighter cable -no problem for 100 watts.
    Mount the relay very close to or on the inverter.
    Run the inverter power switch wires to the relay.
    Supply the ACC signal to one end of the relay coil thru a 1n4004 diode (silver stripe at relay end).
    Supply the 12v hd wire to same end of the relay coil thru a 1n4004 diode (silver stripe at relay end).
    Connect other end of relay coil to ground/chassis.
    I could take a pic of the car setup if you are interested...
    Sep 2005
    Why is the pc in the picture? I have a laptop setup with a hard wired switch to turn it on.
    Yes it would help to have a picture.
    BUT what I basically want to know is will the setup I have pictured work? All I want it to do is supply power to the inverter when car is on and cut power when car is off. To accomplish the auto turn on for inverter I will leave the inverter power switch set to on. Is there any problem doing it this way?
    SUMMER CAR:
    XP MCE/RR/IG
    WINTER CAR:
    '02 Grand Am
    CarPC Coming Soon!
    May 2005
    USA
    Sorry forgot about the laptop bit.
    Yes your setup will work.
    If the original pic had a fuse it would be perfect.
    My suggestion to add the hd 12v just allows the relay to operate while the pc is on the the acc signal is off, like when you are shutting down and want the pc to turn off the inverter.
    Sep 2005
    Where should I add a fuse at?
    Other than that my setup should work perfectly?
  1. relay on a power inverter
    By gtz in forum Hardware Development
    Last Post: 08-16-2006, 06:54 PM
  2. inverter wiring question
    By yonu in forum Power Supplies
    Last Post: 03-17-2005, 11:02 PM
  3. inverter question.... please help..
    By edmonton_mr2 in forum Newbie
    Last Post: 12-16-2004, 06:47 PM
  4. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  5. A newbie inverter question
    By Cliff in forum Power Supplies
    Last Post: 03-29-2002, 10:10 PM
