Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: M2-atx off HU power or not
    Nov 2006
    Hello folks, I'm getting ready to put the m2-atx in, and was wanting to power it off the HU power line. It would be quite easy to do, but I have heard mixed reviews of it on the boards. I am not powering much with the m2, I am far under its specs (HD (new sata2), LCD, via c3, that's it), and would like to avoid running things to the battery and putting holes in the firewall as much as possible, but I wanted to ask your opinions first. I have read of people that it has worked fine for, and think its ok, and I have read people that are vehemently against it. So, recommend it or not, and why?
    Thanks!
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    It all comes down to this.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Nov 2006
    What's standard HU size cable? 10 gauge?
    Elsewhere
    More like 16-18awg
    How about the Wiki?
    Nov 2006
    Ouch, well, here's a thought, I don't want to put any more holes in the firewall (I'm just not that secure in my ability to do that and I don't have a metal drill bit), but I believe I have 1 or 2 gauge wire running back to my 2 amps in the trunk, could I possibly splice into that somewhere near the front and run a wire off of that to my PC (which is in double din slot)? I can't imagine that the amps are using the full power of that wire (i'm not 100% sure on it's gauge, but it is over .25 in. in diameter).
    Any suggestions would be great
    Elsewhere
    Two words: distribution block
    How about the Wiki?
    Nov 2006
    So, I would run the amp power cable to a distribution block, then run the same gauge back to the amp, and an 8-gauge to the PC? Does that sound about right?
    Low Bitrate com2soft's Avatar
    Sep 2006
    i used run an inverter off dis block. it run fine with a manual computer switch. so i think you may want to add a manual switch too.
    Nov 2006
    I have an inverter, but I'd rather run the power straight to the board, since I'd rather it turn on with the car instead of with a switch, and I think the m2-atx is easier to hook up to a power line than plugged into an inverter.
    Nov 2006
    Oh, another thing, where's the best place to pick up a distribution block? Do I need a special one for this gauge of wire?
  1. Pundit atx power connector
    By essamch007 in forum Power Supplies
    Last Post: 08-17-2006, 01:04 AM
  2. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. full ATX mobo and req. power
    By fishy in forum Power Supplies
    Last Post: 10-13-2004, 01:53 AM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
