And yes a simple on/off switch will work. Basically anything that will short something out and then not.
What about a banana connector for the ignition wire. A simple one pole device that can be had for peanuts.
So i want to be able to remove my carpc from my car and use it indoors at times, being as the case is extremely cramped i dont want to open and close it all the time to change J10 on the PSU to switch between Classic and the Car mode, so would a on/off switch stuck in the back of the case be ok to use as a "jumper"? And also does anyone know a good "plug" i can use for connection the IGN wire nicely to my case, something similar to a DC plug but 1 pole although a 2 pole would work...
1.9in x 2.9in -- 47mm x 73mm
