Results 1 to 3 of 3
Thread: Overpowering USB 2.0 Cardbus card
    Jun 2006
    Ok,
    Bought a generic USB 2.0 (2 port) cardbus card for my laptop/carpc.
    Figured I might need more juice as I was going to plug an Audigy into it and a usb 802.11g stick.
    So.....I buy the supposedly matching ac/dc power supply (running an inverter in the car for the time being).
    Plug it in, it smokes the usb wireless stick after a day.
    I pull out the trust multimeter and check voltage:
    7.6 volts!!!!
    WHY? Is there some wacky standard of USB that goes beyond 5V?
    Need confirmation of two things:
    1. This is what most likely killed the wireless stick (smells burnt/wont detect on any machine now)?
    2. Suggest a correct POL supply. I assume the 5V/15W POL in the mp3car store is a good stab. Just want to make SURE I'm on the right path here as I'm less than thrilled throwing $12 for a USB wireless stick down the magic smoke drain.
    Elsewhere
    1. Yes.
    2. That's a good choice.
    Sorry for your loss. HAve you contacted the manufacturer? Theymight reimburse you for the cost of replacing the damaged parts...
    How about the Wiki?
    Jun 2006
    Quote Originally Posted by DarquePervert View Post
    1. Yes.
    Bought it from some flea bag website. Thats what I get for A. Buying too cheap B. Not verifying the voltage when I was soldering all my crap on the bench. I have a multi-meter sitting next to me, but did I turn it on that day? Bzzt. Oh, at least I had my old polarity tester to make sure I wired the barrel connector correctly (had to make the original line longer).
    I guess the real question is why in the world would there be higher than 5V usb hub power supplies?????? Even more interesting is my audigy 2 nx survived the abuse, but the el cheapo usb wireless stick toasted itself. Must be better protection/etc in the sound card.
    On a side note, I've had zero issues with the inverter after I performed surgery on it to remove the internal under current alarm speaker (fun when it would fire up you would get a beep for a few seconds).
  1. Recommend a pci usb 2.0 card?
    By dmcdlrn in forum General Hardware Discussion
    Last Post: 03-17-2006, 01:06 PM
  2. Replies: 2
    Last Post: 09-26-2005, 10:59 AM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. FS: MITSUMI FA404M 7 IN 1 CARD READER & FLOPPY USB 2.0 Grey
    By srcstc in forum Classified Archive
    Last Post: 04-17-2005, 07:42 PM
  5. How many devices on a USB 2.0 hub?
    By sohr in forum General Hardware Discussion
    Last Post: 06-04-2004, 07:13 PM
