Results 1 to 10 of 15
Thread: power switch circuit help (on/off/auto modes)
    Mar 2006
    all,
    i'd like to mount a switch in my dash that controls my carputer. i'd like it to have 3 modes, auto, on and off. i'm using an m2-atx power supply.
    the behavior i would like is as follows:
    on - IGN lead of M2 connected to battery, computer is on even when the car is off
    off - IGN lead of M2 grounded, computer is off even when the car is on
    auto - IGN lead of M2 connected to IGN of car, computer is on iff the car is on
    i have a 3-way switch that is on-off-on. my plan is to wire one "on" pole to the battery, one "on" pole to an ignition switched 12v source and the "off" pole to the IGN lead of the M2 with a pull-down resistor in parallel.
    Code:
             ON  OFF AUTO
    BATT ----o    o    o----- IGN
                \       20K
      M2-ATX o---o---\/\/\/\---> GND
         IGN
    will this circuit work?
    secondly, am i correct in assuming that the M2's shutdown delay will prevent the computer from shutting down as i switch from ON to AUTO or vice versa?
    2006 Corolla S • Ex-Audio 7" • Epia MII • ATI AIW VE • 512MB • Mini-Box.com M300 Case • 100GB 2.5" HDD • Z-COM XI-325HP+ • Linksys WSB24/WRT54G w DD-WRT • Treo 755p BT Modem • Lite-On Slotload DVD • GPS • JVC AVX2 • 2x JL Audio 8" • Alpine Type-S F/R
    Low Bitrate com2soft's Avatar
    Sep 2006
    the ACC wire in M2 control its auto. disconnect it makes it manual. in Manual you need a manual switch (connect to your mobo) to turn on/off pc.
    Constant Bitrate TheLandYacht's Avatar
    Oct 2005
    Austin, TX
    but in answer to your question, the setup you're talking about is EXACTLY as I have it in mine...minus the 12v psu...
    Got that 3way switch on my dash for times when I need to turn the car off for a couple seconds (if the van's engine dies & needs to be restarted for instance, I don't have to cycle the puter).
    Jun 2004
    Rochester
    Yes, your circuit will work, but I don't believe that it is necessary to ground (or pull to ground) the M2's IGN wire. Simply leaving this wire open for "OFF" mode should do the trick. (If you know something that I don't, please let me know because I am planning on doing this as well). And yes, the delay of the M2 will allow you to switch from "ON" to "AUTO" without the PC shutting down.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Mar 2006
    it may not be necessary but it seems like in general leaving an input floating is a bad idea just from an engineering perspective. does anyone know for sure what the M2 does when that lead is floating?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Just get a ON-OFF-ON 3 pin toggle switch.
    Pin 1 connect to battery
    Pin 2 connect to the M2 ACC wire
    Pin 3 connect to the car's IGN or ACC source.
    Operation:
    First ON, PC will be on untill the battery flat
    OFF, well, it off regardless of car's status
    2nd ON, PC on with the iGN key.
    No extra component needed.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2004
    St Louis
    Nov 2004
    Seal Beach, CA
    jigger -
    i use an on-off-on switch. wired it just like MatrixPC recommended. when the switch is in the down position, the computer reacts to the ACC line. when the switch is in the up position, the computer is on. when the switch is in the middle position, the switch is off.
    it works great.
    - O
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
    Jun 2006
    I have the exact same installation .. on-off-on switch!
    the m2-atx handles it just fine! you don't really need to ground the "off state
    VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Belkin Bluetooth V1.2 // Hauppauge WinTV FM
    Centrafuse RC5
    JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Anybody care to post a diagram, please.
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  3. My laptop power on circuit
    By shotgunefx in forum General MP3Car Discussion
    Last Post: 05-11-2005, 12:43 PM
  4. Switch letting power through
    By veetid in forum Power Supplies
    Last Post: 06-08-2004, 02:09 AM
  5. anyone wire a power switch to their Inspiron?
    By sohr in forum Power Supplies
    Last Post: 06-07-2004, 01:35 PM
