Maybe the air is more dry in the winter and thus it's easier for you to build up static electricity?
for some reason i've only started to notice this recently. Whenever I'm in the car, I can feel quite a bit of static electricity between myself and the car seats (cloth). I can really feel my hairs standing on end. Then, when I get out of the car, once I touch the ground and grab my door ZAP!. Shock EVERY time.
So, question is... what did I do wrong that is causing this? I don't seem to notice any other electrical problems with my car.
Thanks.
- O
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
Did you ground your pc through your seats grounding bolt improperly?
Meaning the ground isn't directly getting to the chassis, it has goop and paint inbetween it.
Also, I get shocked everytime too. But this was even before I put the CarPC in. Just when you move around on the seat, you built up some static!
1.9in x 2.9in -- 47mm x 73mm
i haven't even put a carpc in yet and i get shocked every time too. my last car was leather, so i didn't have a problem. this is my first winter in this truck with cloth seats, so i guess i'll just get used to it.
Yep...get used to it. Winter air and cloth seats = shocking exterior! Interestingly, some tires make a big difference as well...I remember that some of the more fuel efficient cars using very narrow, hard rubber tires and some city busses have factory installed grounding straps that touch/brush the pavement to provide a ground for the car's chassis to prevent this situation.
But consider yourself lucky...I used an inverter with my first install that was not well designed, and allowed a ~20V AC current to flow between the computer case/ground and the car chassis...including the ground on things like the audio cables from the computer. I first began to suspect something was wrong when I noticed a distinct tingling in my arm with the audio cable plug in my hand, and my arm resting on my aluminum shift knob (chassis ground). So, I got out my trusty multimeter and took a reading: 20V AC curent! Good thing it wasn't more than a 20V leak.
- Monthly North Texas Meet thread
- My worklog
- gDrive Install pics
- How to add your CarPC specs to your username
An amateur built the Ark. The Titanic was built by professionals.
This has nothing to do with carPC.
I get shock whenever dry wind blow.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Well, thats good to know. I just did a bunch of electrical work, so I was worried that I screwed something up.
Thanks.
