Results 1 to 10 of 18
Thread: Power USB Hub with M2?
    Registered User
    Nov 2006
    I will be installing my CarPC within the next month.
    Currently I have a
    voomPC Case
    M2-ATX
    Via MII-10000
    1Gb Ram
    80 Gb HD
    Holux 271 (GPS)
    Lilliput 7" touchscreen
    USB WiFi
    USB Bluetooth
    USB to HU (Car2PC adapter)
    USB External HD 2.5"
    7 Port DLink USB Hub
    I know I will power the LIlliput off the 12V Rail of the M2-Atx power supply. But I also want to power the USB Hub.
    The USB Hub has a 5V 3A Requirement to power. So If I connect the 5V from the M2-Atx, will this work? or will it fry the USB Hub?
    According to M2-Atx
    Maximum Power Characteristics
    Output Rail - Current (Max) - Current Peak (<60 seconds) - Regulation
    5V 8A 12A 1.5%
    3.3V 8A 12A 1.5%
    5VSB 1.5A 2A 1.5%
    -12V 0.15A 0.2A 5-%
    12V 8A 9A 2 %
    It says the 5V rail has 8A, will that be too many amps?
    on a side note what is the difference of 5V and 5VSB? Besides the obvious difference in Amps.
    Thanks.
    Arty
    Low Bitrate rjankowski's Avatar
    Oct 2006
    TN/KY Home is Houston
    Just what I would do:
    Stick an ampmeter between your M2 and your mobo (probably going to have to cut something) and see how much your pulling with every thing on and running. If you have less than 3A draw on the +5v you can make the call to run it off the power supply or not, its your choice to live with.
    If I were in your situation (I will be when I get back to my truck), I would look around here in the hardware fourms and see if you can find a simple +5v power supply. If you can build it, it may be your best option.
    +5v is your normal +5v rail. +5vSB is your +5 stand by voltage, it is what powers your computer so that a PSON signal can be applied. Dont draw anything off of that, probably not a wise idea.
    And your device will only pull as many Amps as it needs, the M2 can supply up to 8A continuous, but depending what you have on it, it may only be pushing 3A to power those devices.
    It works!!
    Almost all of the time too!
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Arty13 View Post
    Currently I have a
    voomPC Case
    M2-ATX
    Via MII-10000
    1Gb Ram
    80 Gb HD
    Holux 271 (GPS)
    USB WiFi
    USB Bluetooth
    According to M2-Atx
    5V 8A 12A 1.5%
    3.3V 8A 12A 1.5%
    5VSB 1.5A 2A 1.5%
    -12V 0.15A 0.2A 5-%
    12V 8A 9A 2 %
    Thanks.
    Arty
    Why would it fry the usb hub?
    Michael
    Newbie roedkaelk's Avatar
    Jun 2006
    Denmark
    5v power to USB hub
    My USB hub is powered directly from the 5v rail on the M2atx. Works fine here... Dont know if it is supposed to work though!
    My v70 carputer worklog...
    CarTFT MM400 | ASUS N4L-VM DH | Intel Core Solo T1300 1.66 GHz
    2 * Kingston 512 pc2 5300 | Seagate Momentus 5400 100 gb
    G.Mouse BU-353 | M2-ATX |
    Running Streetdeck
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    I was thinking along the same lines except that the M2 would fry (if overloaded) as opposed to the hub. That's why i bought a AC powered USB hub and will power it with an inverter that i already have.
    Registered User
    Nov 2006
    Would I be able to add a resister to the 5V rail to bring down the Amps to 3?
    Also what harms can come out of running the 5V with the max 8Amps to the hub?
    But otherwise my main/real option should be finding/building an external 5V/3A powersupply to power the usb hub?
    Thanks again.
    Arty
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Thanks again.
    Arty
    ONCE AGAIN, why would the HUB fry.
    Think of it. If, as you seem to think, that ANY device taking power from the M2 will EAT UP/TAKE/CONSUME/USE ALL of the available amps the M2 has, then as soon as you connect a Hardrive, or MB, or Screen, to the M2, NOTHING ELSE WOULD WORK, BECAUSE THERE IS NO MORE AMPS TO TAKE. Or better yet, if you power your home computer with a 350 watt, or 500 watt PS, UNLESS THE SYSTEM IS EXACTLY 500 watts, then poof, your system is toast cause the M2 is gonna FORCE ALL THAT AMPERAGE into the system
    Come on man, think a little.
    Better yet, READ THE DAMN FAQ, cause I explain this myself in the faq section.
    Michael
    Registered User
    Nov 2006
    Sorry if my questions come out stupid, I did read the faq, but I have other people telling me different things. Maybe they dont know what they are talking about.
    And I should of stated my 'Frying' more clear. I didn't mean the USB Hub alone, I was trying to state that what could "fry" by hooking all the stuff together.
    Here's a different question regarding M2 and max Amps.
    When it says 12V 8Amps Max and 5V 8Amps Max, does that mean each rail has a max of 8Amps, or is that saying the M2 only produces a max of 8Amps total?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    First, DON'T LISTEN TO OTHER PEOPLE. The FAQ is correct, that is why it is a FAQ. If it changes, the FAQ will change. I hope you wouldn't ask a lawyer for advice, and then listen to your friends about the law, or speak to a doctor about a medical condition, but listen to your neighbor about it because "he knows these things" The Faqs were created by "experts", no need to listen to anyone else.
    You are obviously new to this stuff, and should have posted in the newbie section. I am generally "easier" when people post in the Newbie section.
    Now, lets look at things logically, when was the last time you saw a Powerr Supply rated by AMPs. Probably never, hell, the M2 says it is 160watts, and most desktop PS are like 350 watts. So, I know that the M2 is 160 watts, and it has 8 amps, what does that all mean? Well, I go to and put in "amps watts", and the first thing that comes up is http://www.powerstream.com/Amps-Watts.htm Of course, you could search THIS forum and find the same thing, but google is easier to use. You would now know that amps*volts=watts So, (12*8)+(5*8)+(3.3*8)=VOILA, 160 watts. Go ahead, if you can find the amp specs for your PS (it is usually on a sticker on the side of the unit, though you might need to open the case to see it) see how the math works out.
    Now, you said you read the FAQs, and first, well, I don't think ANYONE has actually read all the Faqs, which means you have to search them. I KNOW there is a FAQ about this stuff because I wrote part of the faq. Can you link me to the faq that you felt was relevant to your question but did not actually have the information.
    To make it easy, I have searched the FAQs and found the relevant posts in the Faq Emporium.
    First, lets start here Attention Newbies! A FAQ to the FAQs
    We then see
    "Powering A Car PC
    1. Power supplies for car PC's EXPLAINED includes description of the most popular power supplies for car PC use.
    2. Will {insert power supply here} this power supply work with my car PC? An excellent writeup by member Darque Pervert to help demystify the power supply world.
    3. How to choose a power supply - a writeup at the Carnetix web site. Vendor writeup that includes discussion about the challenges of powering a PC in the automobile.
    4. How to keep your car from bursting into flames because you picked the wrong size cables: Ensuring you use the proper size cables, Choosing the proper gauge wires
    5. How to wire an Opus
    6. How to fix your Opus
    7. Tips and pitfalls to avoid with your M1-ATX power supply
    8. How to power your CarPC when it is NOT in the car."
    All you could ever want to know about carPC power supplies.
    Then, the thread with the specifics about your question,
    FAQ: Power Supplies Explained (Part 1) FAQ: Power Supplies Explained (Part 1), In particular, this post http://www.mp3car.com/vbulletin/show...01&postcount=4
    HUH? Stating means making a statement, usually of fact. "What" implies a question, and is not "compatible" with a statement. Assuming what you mean is "what could "fry" by hooking all the stuff together" Why would something fry because you hooked them all together? I guess maybe the PS could be overloaded and ruined if you tried to pull too much power from it with your system, BUT, that is why you newed to read the faqs, and figure out how to determine what PS you can run on what system. It is called a power calculator, and I can assure you, there is information about power calculators in the FAQ Emporium.
    Michael
    Constant Bitrate jeep642's Avatar
    Sep 2006
    Chevy Chase, MD
    I didn't read all the posts (kind of in a hurry ) but here's my 2 cents. (sorry if someone already explained this)
    It's more or less like this:
    If you're lookingt at a pipe containig water, the Amps are the size of the pipe the Volts are the pressure in the pipe (more or less, the speed of the water inside the pipe)
    so...
    you can have issues if the voltage is not correct but
    for the Amps, as long as you need less than what you have, you're fine:
    in other words 5v 8A out of the M2 and you need 5v 3A for the hub. The hub will only take what it needs.
    The M2 is not gonna "force" 8A inside the hub it's just gonna have 8A available to anything you plug in the M2.
    If the sum of all the devices using the M2 for power is more than 8A, then be careful the M2 is gona overheat and the devices will run on less power tan they require.
    as I said....my 2 cents...hope it helped
    JP
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
  1. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 06:22 AM
  2. USB power question
    By maxxell in forum General Hardware Discussion
    Last Post: 04-13-2006, 04:06 PM
  3. Usb hub power source?
    By dmcdlrn in forum Power Supplies
    Last Post: 04-01-2006, 03:03 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 07:34 PM
