Results 1 to 9 of 9
Thread: sproogy and hard disks
    Oct 1999
    London England
    I tested out me sproggy with just a quantum harddisk as the load which requires
    peak 5v @ 700mA and 12v @ 1,700mA
    normal +5v @ 600ma and +12v @800ma
    When i switch on the sproggy the hd just keeps clicking and wont spin up. Isnt the sproggy 2.7 meant to supply 2amps on the +12? What do i need to do to get the hd to work?
    FLAC Mastero's Avatar
    Aug 2001
    India
    The problem is not your Sproggy its the input to your sproggy try to connect it to the car battery and see.. !
    Mastero
    Oct 1999
    London England
    tried that
    Oct 1999
    London England
    since my setup dont need -12v will disconnecting the capacitor and 78l05 give me a bit more juice on the +12?
    Aug 2001
    India
    Then i guess you will have to put a amp meter in between the hdd and see how many amps its pulling !
    Post the results here !
    Oct 1999
    London England
    dont think me multimeter is working correct coz it dont register any current and tried it on other stuff as well and i was measuring in series also
    Jul 2000
    Israel
    Sproggy's PSU is giving 1.2A at 12V. I had exactly the same problem.My HD needed 2.5A for spin-up.I connected HD directly to the car's battery (using relay),this worked fine for me for a year,but now it's connected to 2 MAX1771 outputs which gives me about 3A,that's enough for HD.
    Oct 1999
    London England
    does using that chip allow you to crank your engine or do you have to switch off your car computer first?
    Jul 2000
    Israel
    you can start the engine and it doesn't affect the HD.
