Results 1 to 7 of 7
Thread: Best place to mount a P1900?
    Dec 2006
    in an 04 G35? i will be using an Aopen Pandora, putting it in the upper glove. ive seen someone else's worklog and they have it mounted in the upper glove somehow right next to the pandora. just wanted to get anyone opinions, best practices, etc. thanks in advance.
    j.
    Nov 2006
    i dont think it really makes much of a difference?? jsut wherever you can it to fit.. mine is just sitting in the trunk.. not even mounted. lol
    Dec 2006
    hmm, well wanted to keep in the glove since none of the pc components are going in the trunk. theres probably some space in the dash...somewhere.
    Nov 2006
    yeah its really small im sure you could find a spot.. im just lazy haha.
    Mar 2006
    Colorado, but Canadian!
    Anywhere you can squeeze it that is infront of the firewall and behind the dash.
    What about on the other side of the glovebox. Usually some extra room there. Or on the back of the screen if you are molding in a double din.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2006
    awesome. thanks for advice guys. i did some fitting and i think it will mount nicely to the side of the din converter in the upper glove. right next to the pandora.
    Jun 2006
    Ventura County
    Quote Originally Posted by st_abbott36 View Post
    That's where I put mine
  1. Headrest Mount
    By kwiebe in forum LCD/Display
    Last Post: 09-12-2006, 08:48 PM
  2. Carnetix p1900 and Travla c138 120watt?
    By john_draws in forum Power Supplies
    Last Post: 05-27-2005, 01:42 AM
  3. p1900 is perfect -except for one quirk:
    By crazymadbastard in forum Power Supplies
    Last Post: 05-24-2005, 07:48 PM
  4. Replies: 6
    Last Post: 04-02-2004, 04:01 PM
  5. Replies: 0
    Last Post: 07-14-2003, 04:12 PM
