Results 1 to 4 of 4
Thread: I need help sheilding an inverter.
    Apr 2006
    Saint Petersburg, FL & Flint, MI & Auburn, NY
    How exactly would one shield an entire housing of an inverter without having it over heat? I'm trying to minimize emi leakage if I potentially have any. Better to have it done first than wait to redo lots of stuff.
    Obviously I know foil is probably one of the most popular sheilding materials but how should it be done?
    ___________________________________
    1996 Accord Ex Carputer
    Soon to come 2008 WRX 5-door Mac-carputer.
    Oct 2006
    I'd say try it out first, and if it ain't broke, don't fix it. I've never had an inverter cause interference problems, and I've had several. If it does, I'd suggest painting it with Conductive Shielding Paint (used in electric guitar electronics cavities). It's not the cheapest stuff (about $20-$40 for half a pint), but it should let your inverter breathe well, and once its there, you won't have to worry about it getting torn like foil.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Mine was causing some noise but grounding the case (to the groung distro block) solved the problem. install it and see what happens..you may get lucky!
    Apr 2006
    Quote Originally Posted by izzy3153 View Post
    Quote Originally Posted by treetop777 View Post
    Okay well I tested it. The sound is perfect for my normal speakers but my subs emit a decent level of humming and they still play. I'm not sure if that makes sense because if the interference was affecting it wouldn't it hit the normal car audio?
  1. relay on a power inverter
    By gtz in forum Hardware Development
    Last Post: 08-16-2006, 06:54 PM
  2. Problems I've had with inverter (Sima 300w - 600w)
    By dagnasty in forum Power Supplies
    Last Post: 01-21-2006, 10:13 AM
  3. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  4. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
