Results 1 to 4 of 4
Thread: Universal charger causes VGA noise, where to ground?
    Aug 2006
    Hi all,
    after finally getting my lilliput back from repair i'm hoping to finish my car pc, but my last problem is noise on the screen when my charger is plugged into the laptop..
    Here is the scene:
    Car ISO connectors to speakers + power
    Lilliput 701NP/C indash
    | USB | VGA | 2x RCA + GND loop isolator
    | | | 3.5mm Stereo Jack
    Toshiba Laptop
    | Universal Laptop charger
    Car Cigarette lighter socket
    Now everything works perfectly when running the laptop from batteries, but as soon as I plug the charger in I got ground loop noise, so I tested the charger when it was wired to the same power and gnd as the lilliput screen - not much difference in ground loop noise (maybe SLIGHTLY better)
    So I got myself a ground loop isolator and now the noise is gone, but its now finding a route through the VGA lead to the screen causing horizontal lines..
    I have quickly tested grounding the metal plate where the VGA, USB, Serial etc.. is on the back of the laptop to a point on my chassis and the picture does improve but there are still lines visible...
    I am going to test with the charger back on the same power as the lilliput tomorrow and maybe ground the back plate of the laptop to the same point.
    Is there anything else I can try? I was wondering if I should be grounding anything else to the car ?
    Thanks for any suggestions!
    Maximum Bitrate carabuser's Avatar
    Aug 2003
    CA
    How's your Lilliput powered again? I didn't quite get it from the diagram.
    I had a similar problem, but mine was powered by an inverter, running from the cigarette lighter. My way out was to ground the charger of the Lilliput. My laptop charger/power supply is grounded to the chassis as well (different point though). Make sure you know which part of the plug is negative and try to ground it.
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
    Aug 2006
    hehe, sorry about the poor diagram!
    my lilliput is the indash model so it connects directly to the cars stereo wiring loom, which is where i plan to test grounding the charger to tomorrow..
    Aug 2003
    CA
    duh, it says it right there.
    Try grounding the power wire that plugs into the laptop itself and see if there's any difference.
    Specs
    - Pioneer HU (sold)
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. The quest for no noise
    By mp31500 in forum General Hardware Discussion
    Last Post: 04-02-2007, 11:12 PM
  3. Intermitent induced noise in my vga signal?
    By Farrow099 in forum LCD/Display
    Last Post: 12-27-2006, 02:41 PM
  4. Noise Problem(Yes I saw the sticky)
    By diablodemorte in forum Car Audio
    Last Post: 10-04-2006, 06:16 PM
  5. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 02:23 PM
