Results 1 to 10 of 12
Thread: Amplifier remote wire good for M2-ATX?
    Aug 2005
    Plano/College Station, TX
    Can I use an amplifier remote turn-on wire as a source for the "ignition" lead of my M2-ATX? The M2 manual doesn't say if the ignition lead needs a specific voltage or not, save that it needs to be positive. My carputer is located near my amps and far from any other switched 12V leads, so if I can, I want to just tap off the amp remote wire and run that to my M2-ATX.
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    this is the way to go
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
    Aug 2005
    So it's cool if one wire is running to an amplifier AND to the ignition lead? If I'm thinking right that would be putting the M2 and the amplifier in parallel with eachother, and the voltage should be the same across two parallel paths, but basic electrical theory never was my strong suit. I appreciate the help!
    Mar 2006
    Colorado, but Canadian!
    yes exactly. The voltage will be the same, the current will be halved. But the current drawn is soooo small because it is just a remote on wire, that it should be able to trigger many devices.
    1.9in x 2.9in -- 47mm x 73mm
    Sharjah, Emirates
    I have the ACC/IGN wire connected to 2 amps and the M2, all in parallel, no problems at all. i wanted to use the M2 remote amp turn on for the amps, but it turned out to be crappy with so little a current.
    Final Touches
    Aug 2005
    Alright great thanks a ton guys!
    I've got my headunit sending 2 remote wires to the back of my truck for my two amps, so tapping one of them to send a +12V signal ought to be very easy. I appreciate it!
    Mar 2006
    what is the best size wire to use for the ign wire? or does it really matter? I got alot of speaker wire laying around, could that be used, or is somehting specifig needed.
    Elsewhere
    IGN wire doesn't carry a lot of current, so a smaller wire (higher gauge) is fine.
    Mine is 18awg, I beleive.
    How about the Wiki?
    Sharjah, Emirates
    Quote Originally Posted by DarquePervert View Post
    i used speaker wires no probs.
    Final Touches
    Jun 2006
    how much current does the m2's remote give out?
    its not working with my new amp (drops to 5v...) lol
  1. opus remote wire doesnt turn off amp
    By evilragu in forum Power Supplies
    Last Post: 08-17-2006, 04:44 AM
  2. M1 ATX Remote voltage
    By thenick100 in forum Power Supplies
    Last Post: 01-18-2006, 09:59 AM
  3. Instruction For Atx Shutdown!
    By Mastero in forum Power Supplies
    Last Post: 10-17-2002, 03:44 PM
  4. ATX Power Good?
    By JesTa784 in forum Power Supplies
    Last Post: 06-18-2002, 06:22 AM
  5. Atx Power Good?
    By mp3z24 in forum Power Supplies
    Last Post: 02-28-2002, 04:23 PM
