Results 11 to 20 of 21
Thread: Did I hook something up wrong? M2-ATX problem
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Like Toaster said,
    If the unit is actually connected the way you said it is, with the constant power and ingition power to the battery positive, and the ground to the negative, and in Dumb PSU mod, and you have no power on the ATX wires, then something is wrong.
    Confirm you have installed the wires correctly. Confirm your jumper settings. Check your board for anything that looks borken or burnt up.
    There is a known issue with the M2 and the Epia boards, you can look into that as well, but again, no power on the ATX wires means something is wrong. Have you check the on board fuse to see if it is good. You said you confirmed power to the M2 is good, how did you do that/where did you test?
    Michael
  2. #12
    Aug 2005
    Plano/College Station, TX
    The fuse on the M2 is not burnt or broken. Nothing I can see on the board looks damaged either. I didn't get any sparks, smoke, or burning smells when I hooked up the M2.
    I've checked, double checked, triple checked my wires, my jumpers, and anything I could fathom related to how I hooked up the M2. Everything seems to be alright there too.
    I used a multimeter to check that the M2 was getting power from the battery. It's getting 12.4 volts on both the power lead and the ignition lead.
    I ordered an OPUS 120w today, it should be here on Monday. We'll see how the OPUS handles. I may send the M2 over to my electrical engineer buddy and see what he can figure out.
  3. #13
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Gearhead61 View Post
    WHERE did you check for voltage going to the M2?
    Also, how/where did you test for voltage on the ATX connector?
    Michael
  4. #14
    Aug 2005
    I pulled the fasteners off that connect to the M2 (the spade connectors) and tested the voltage on each of those leads. Then I reconnected them and tested the power coming out of the ATX connector. I put the red probe from my multimeter into the connector and then put the black probe into a pin that was a known ground on the connector. Did I do that wrong?
  5. #15
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Did you check the ignition and power leads against the same ground to which the M2 is wired, or another, seperate ground?
    Is the M2 ground a known good ground (other installed equipment operating succesfully with the same ground, etc...).
    Sorry if this seems simple, but I've had grounds test good with multimeter that fail to operate my equipment in the past....and you didn't specifically mention checking the ground.
  6. #16
    Aug 2005
    Initially I had my carputer hooked up to my amplifier distribution blocks, and I know the ground block has good grounds because I don't have any induced ground loop noise, even with my RCAs running next to my 1/0 power cable (I know it's kind of a no-no, but it's working well for me so far). After it wouldn't work there, I pulled the carputer out and hooked it directly to the + and - battery terminals to see if I couldn't get something. That is when I pulled out the multimeter and started measuring.
    Thanks for the help, even if it's really basic help. I'm not VERY good with this stuff, so even just reinforcing the basics is very helpful. Any ideas on anything else I might have done wrong? I feel like I've checked and tried everything, but there could be something really basic that just completely slipped by me like you just asked?
  7. #17
    Nov 2006
    not sure if you got this fixed yet ?? but could it be becuase you have the white cable, remote hooked up to the positive terminal on the battery ?? isnt the white cable suppose to be hooked to the ignition cable ?? and not directly on the positive terminal ?? try unplugging the white cable and just leave the black and red in tehre and see how that goes ??
  8. #18
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by CoupeE46 View Post
    Nope, it is not that. The white wire is for ignition, and all the ignition does is wait for 12 volts on that wire. If there is 12 volts, like the car is running, then the M2 says, Hey, time to power on. Remove the 12 volts, and it says, ooops, car is off, time to power down. Putting it to a constant 12 volt source tells the M2 to power on. THe m2 doesn't care if it is an "ignition" wire, or a constant wire. It only knows to look for 12 volts, which it is getting.
    As said before, if you have good positive, switched, and ground, and ar in dumb PSU mode, and there is no power on the ATX connector, there is a problem with the M2
    Michael
  9. #19
    Nov 2006
    Quote Originally Posted by Wiredwrx View Post
    Michael
    ok gotcha.. so for testing purpose i can just connect the White wire to the same positive terminal i connected the positive lead to, and it should still work correc t?? thanks.
  10. #20
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Do you mean "and it should still work, correc t?? thanks." or "and it should still work correc tly?? thanks."
    It will work. It won't, however, work correctly in the sense that it won't shutdown unless the white wire is removed from positive.
    Michael
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 09:28 AM
  2. Replies: 1
    Last Post: 10-05-2006, 04:28 AM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 11:24 AM
  4. sproggy 2.6 problem
    By jrbless in forum Power Supplies
    Last Post: 06-04-2002, 02:44 AM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 08:00 PM
