Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Did I hook something up wrong? M2-ATX problem
    Aug 2005
    Plano/College Station, TX
    Well I can't seem to get any power whatsoever from my M2-ATX. I looked around a few of the M2 problem threads but nothing really stuck out to me.
    I've got my mobo, M2, RAM, and HDD in the computer right now. I've got the leads for ground, power, and ignition directly wired to the battery, ground to negative, power and ignition to positive. The M2 has the power button from the case attached to the J9 jumper, and the M2 is wired to the power button jumpers on the mobo (pins 6 and 8 on my M10000) from the J8 jumper. I've tried switching the polarity of the J8 jumper since it's not labeled which pin is + and which is - on the M2 or in the manual. The 'function' jumper on the M2 is set to B which is 5 sec/2 hours as the M2 manual suggests.
    Am I missing something here? Shouldn't I be getting SOMETHING atleast when I touch the power wires to the battery? As it is right now I'm not even getting spinning fans.
    Mar 2006
    Colorado, but Canadian!
    What happens when you short the mobo manually?
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    how do I do that? You described it in another thread but it didn't make much sense to me
    Aug 2005
    Ok well I tried this:
    I took the jumper off of the power switch pins on the motherboard. The M2 is still plugged in to the motherboard and the hard drive power spots. I hooked power to the M2 from the battery, and then used a small screw driver to touch the two power switch pins on the mobo. Did I do that right? Because when I tried that, I again got nothing. No spinning fans, no beeps, nothing. The jumpers on the M2 are set to "dumb PSU" mode.
    EDIT: I'm no pro with a multimeter, but I did test and the M2 is getting power through the ground, power, and ignition leads. It is NOT, however, making any sort of output through the ATX connector. Does this mean I've got a toasted power supply?
    Mar 2006
    Yes you shorted it right assuming the jumpers you shorted were the on/off pins. If there is no power through the ATX connector, then something is wrong. Check pin 14. Greenish. That always has power. It is what is actually used to turn on the computer.
    Aug 2005
    No dice on pin 14. Went ahead and tried all 20 pins and all the molex connectors to the HDD and such. Completely dead.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by Gearhead61 View Post
    Does the MB work with a known good ATX supply?
    Aug 2005
    The MB has worked fine for me using a standard home ATX power supply. I've been working on setting up my front end, GPS, music, and phone control in the house and I went to install the carputer in the truck once I'd finished and the M2 just decided it didn't want to work for me.
    Aug 2005
    Damn triple post, lol. Sorry guys.
    Aug 2005
  1. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 10:28 AM
  2. Replies: 1
    Last Post: 10-05-2006, 05:28 AM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  4. sproggy 2.6 problem
    By jrbless in forum Power Supplies
    Last Post: 06-04-2002, 03:44 AM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 09:00 PM
