Results 1 to 5 of 5
Thread: Opus in an Ampie(Voom) Case? / First post
    Newbie akwash79's Avatar
    Jan 2007
    Long time lurker, first time poster. Anyway, I've recently got started purchasing parts for my carputer. After hearing about the many problems other users have had with the m2-ATX, I've decided that I will NOT go that route. So I have a few questions:
    Will the opus 120w fit into an Ampie(Voom) Case?
    If not, will the M1-ATX be enough to power this system:
    EPIA M10000 MB w/ 1.0ghz CPU
    512 MB ddr ram
    120 PATA Laptop HD
    Standard PATA DVD/CD Drive
    USB GPS
    USB FM Tuner
    USB Bluetooth
    USB Wi-fi
    XM Timetrax dongle
    USB Phone charger
    (lots of usb, i know)
    Being that I haven't heard as many problems reported with the M1 as with the M2, is there a general consensus that the M1 is more reliable?
    Any help would be appreciated
    Elsewhere
    There's no room for the Opus, I believe. The dimensions are different than the M-series. Hell, your 3.5" HDD isn't going to fit in the Voom case, either. It's designed for a 2.5" laptop HDD.
    As far as an M1ATX, I'm certain that you're going to be pushing it's power limits with the 3.5" HDD. It might work. It might not.
    How about the Wiki?
    Jan 2007
    actually its a 2.5 laptop drive. I put pata next to it by mistake
    Elsewhere
    That's a good thing, then.
    You should be OK, although the multitude of USB devices might cause you power issues. Nothing a POL PSU couldn't resolve for you, though....
    How about the Wiki?
    Dec 2004
    Is there any cases that an Opus 120 will fit into with minor modification? (minus the Opus Cases because they won't sell a case separate from the 120w PSU that is already in there)
  1. Replies: 3
    Last Post: 11-26-2006, 03:46 PM
  2. Keyboard language indicator extension plugin
    By tolisn in forum RR Plugins
    Last Post: 09-13-2006, 04:49 AM
  3. Runnin an Opus 150W Shutyle revision (fanless) in a case...
    By justintime in forum Power Supplies
    Last Post: 09-06-2005, 01:03 AM
  4. F/S Opus Vehicle Case with 90 watts Opus
    By Darek85 in forum Classified Archive
    Last Post: 08-18-2005, 02:21 AM
  5. FS: Opus 150W, 60GB HD, Sereniti case
    By aoLhaTer in forum Classified Archive
    Last Post: 01-30-2005, 04:38 AM
