Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Buzzing sound in speakers!
    Mar 2005
    Sweden/Vaxjo
    Hi peeps!
    I've been running my laptop in the car with a 12-220V inverter in the trunk, I've had some low buzzing sound with it but it never was a problem...
    Today I connected my carpc for the first time to the inverter and the sound was terrible, it was much louder then when I was using my laptop and I couldnt even be in the car at the same time... I'm running a simple cable from my soundcard to the my 2 amps, one for the speakers and one for the sub's!
    Any solution to this or do I need to buy a new one... (going to get a M2-ATX when I get the €€€)?
    Swedish site for CarPC's
    http://www.bilpc.info
    Low Bitrate Vinster03XR's Avatar
    Jan 2007
    Near Toronto but not in it
    I had that problem when having the inverter too close to my laptop or power wires for inverter getting too close to my audio cable from the laptop.... as long as I keep that in check I have no issues...
    if your wire need to cross make sure they are 90 degrees from each other....
    otherwise try using a filter on the power feed to your laptop.
    Vin
    Carputer works... but will never be complete....
    Aug 2005
    Plano/College Station, TX
    Read up on induced ground loop noise. You'll find a lot of possible solutions to your problem. Also consider getting some more high-quality cables and using twisted pairs of speaker wire.
    Constant Bitrate Zeroaviation's Avatar
    Feb 2006
    Birmingham, Al/Overland Park, KS
    And also look into a "ground loop isolator" i used it when i was running a laptop and inverter, cured it right up, it would go on the input side of the amps, (if ur using a mini--> RCA cable)
    Im a pilot.
    I have become a cross control stall.
    Mar 2005
    Sweden/Vaxjo
    Thanks!
    I've been reading some now, going to check the ground connections everywhere tomorrow if I get the time before work... might try and ground the inverter 2 and see if that helps!
    a ground loop isolator sound like a good way to, problem is I'm from sweden and have never heard of it before, and can't figure out what it might be called in swedish so how do I explain for the nice person in the audio store what I need...
    Newbie toxiclows's Avatar
    Sep 2006
    ground the power supply of your carpc to a nice clean chassis ground. . . . .get some nice rca shielded cables and a ground loop iso. . . . that fixed 99 percent of it for me. . . . . mine was realyl bad. . . . now is totally enjoyable. . . . .. its a big pain to get all this cool stuff hooked up oin your car and then have it almost unuseable due to noise spend some time getting proper grounds and running calbes properly and you will nave a lot nicer setup in the end.
    chris
    Mar 2005
    Sweden/Vaxjo
    I'm sure it has something to do with my inverter since I don't have this problem if I connect a mp3 player or something to my amp's...
    I have a extension cord between my trunk and the front seats where I had the laptop, I think it might have something to do with this since if I disconnect it the buzzing is almost gone. Going to extend the cables to the monitor and so on tomorrow to see if it helps, maybe I'll try and ground the Computers chassis to and see if I can get rid of that last little buzzing!
    Raining like hell here in sweden like now and something like +4C outside so I hope it's some better weather tomorrow!
    Feb 2006
    Grould Loop Islolator, lol, i dont know how to translate that, lol, i dont suppouse you guys have walmart over there? the extension cord, is bad idea, imo, GOOD LUCK
    Im a pilot.
    Jan 2007
    What a buddy of mine did is open the laptop up and add a connection from the ground inside the laptop to the chasis ground of the car..... that way you have the same ground potential.... but try ^ stuff first... it's easier..
    Vin
    Mar 2005
    Sweden/Vaxjo
    Well finally I got the computer moved from the backseat to the trunk, and the noise is almost gone now... if I mute the sound I can still hear it... I actually found a ground loop isolatortoday , was printed in english on the bakside, so I bought it hoping that it would get rid of that last irritating noise...
    Plugged it in and it sounded 20times louder again as soon as I powered up the 12-220 inverter... felt kind of strange since I have been reading about all the guys here that it worked 100% for... any idea why the noise became worse?
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. Does Speakers "Age" affect sound quality ?
    By SUVputer in forum Car Audio
    Last Post: 10-29-2006, 03:05 AM
  3. Replies: 5
    Last Post: 07-26-2006, 12:17 AM
  4. SOUND_Pop on speakers when sound resumes
    By Konrad in forum FP Bug Reports
    Last Post: 07-25-2005, 01:13 AM
  5. HardDrive SOUND in the speakers !!!!!!!
    By KRyZ in forum General Hardware Discussion
    Last Post: 03-10-2000, 02:19 AM
