Results 1 to 6 of 6
Thread: Does a opus power supplie contain a relay/other question.
    Dec 2006
    Im almost starting to build my carputer, I have a last question about my power supllie.
    Im gonna buy a Opus power supplie still not knowing which exacly.
    Does a Opus dc-dc converter has a build in relay?
    Can I use my cigarette holder as a trigger for the relay? ( my cigarette holder goes on and off togeter with my ignition ).
    So I just need to connect my cigarrete holder to my relay on the dc-dc converter, make sure it has power. And when I turn my ignition on it will trigger the opus to give the carpc power. Is this correct?
    Thank you very much for your respons!
    (Does mp3car ship to Belgium?)
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    the OPUS does have a ignition trigger... and yes you can use your cigarette lighter plug as the source for that.. although I would run a wire from the fuse box..
    Dec 2006
    See I still not get it.
    Run a wire from the fusebox to where? The opus you mean?
    Maybe a little pic will help, I mean is this correct and is the pointed wire neccesairy?
    Thank you
    Aug 2004
    Pearland
    you have to use that wire if you want the OPUS to turn your pc on and off automatically for you
    Dec 2006
    Ah okey, thank you for the reply, I finally understand, time to start building me some.
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    you can save yourself the trouble of the lighter and just get a fuse tap. Hook it into a fuse in the fusebox that is activate by the ACC position.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. opus power supply question
    By septicdeath in forum Power Supplies
    Last Post: 07-08-2004, 04:25 AM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
