Results 1 to 5 of 5
Thread: M1-ATX burnouts
    Constant Bitrate trance728's Avatar
    Mar 2005
    Huntington Beach, CA
    M1-ATX burnouts
    I have 3 dead M1-ATX's, I have no idea what exactly happened to any of them but the fuses are not blown and there is some power going to the rail but not the full amount. Has anyone encountered this, and is it a simple fix or are they garbage?
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    send them for replacement if you bought them from official dealers of minibox
    they are kaput
    i have had this happened to my m1-atx, i got a replacement
    Yev
    R. T. F. M
    _
    Mar 2004
    Little Elm, Texas
    did you connect them to your amplifiers?
    if so, did you connect both pins to the amps? or just one?
    If you connect both, you'll run into a problem.
    I do find it strange that so many folks run into problems. I'm still on the same M1 from about 2 years ago....:|
    Jan Bennett
    Mar 2005
    i never had it hooked up to an amp, i just think they may have been shorted somehow by static electricity, maybe?
    Aug 2006
    Nottingham, UK
    If the fuses aren't blown then it sounds like one of the rails is exceeding its capacity but the others aren't...so the overall current draw isn't over 10A
    I almost smoked mine last week from tring to run my screen off the amp turn-on feed. Whoops.
    What's that burning smell?
  1. M1 ATX, hangs. Help a swede in need.
    By Biograph1001 in forum Power Supplies
    Last Post: 11-18-2005, 10:01 PM
  2. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  3. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 09:03 PM
  4. m1 atx 90watt...is it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 12:06 PM
  5. Wanted. M1 ATX Lead..
    By CdRsKuLL in forum Classified Archive
    Last Post: 08-12-2005, 10:57 PM
