no, do NOT "ground" as 120v device (powered from an inverter) to a car chassis. That is very very bad.
Humming is likely a power issue. Try a different inverter.
Ok, I got my 15" dell ultrasharp screen above the passanger seat glove compartment, a dell 4600c computer in the trunk, and the best buy 750W continuous power supply in the trunk. I finally got the sound hooked up today and tested everything out. The monitor is making a weird humming noise and so is the audio from the computer at high volume.
I figured I have to get a ground loop filter for the audio, but do I ground the power from the computer monitor? Can you ground a 120V device onto the car chassis?
I took the monitor home and tested it and it doesn't make noise at home... So it would be nice to have this fixed, the audio too.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
i thought humming was good
sorry i couldn't resist.
beer replenishment fund
mp3car live search
What are the good brand names? Which are the best? I'm using a vector from best buy and it makes my monitor and speakers buzzz.
is there a reason you are using an inverter?
are you opposed to using a DC-DC power supply?
Jan Bennett
well, i'm using a dell 15" ultrasharp and its humming with a regular inverter. so i need a better one. my carpc is a dell dimension 4600c... The audio buzzes at high volume. I connected my laptop to the inverter and the audio buzzes at high volume, off the laptop battery the audio is clear.
ok, so I guess I need a Pure Sine Wave inverter. Thank you Bizarro for the FAQ. Now what are the good brand names? I would need about 400-600W...
How do I go about using a DC-DC inverter with my monitor and computer?
how to use a DC-DC PSU you mean?
You're not inverting anything, so it's not called an inverter.
How do you use it?
I think some reading is in order. You need to look at some work logs, some diagrams, and some PSU manuals to understand it.
Basically, the DC-DC PSU would replace your PSU for your PC that you're using now.
Jan Bennett
