Results 1 to 10 of 14
Thread: Diode Polarity (This is REALLY dumbass :) )
    Dec 2001
    Paignton, Devon, UK
    Ok, I've just got my pcb's from mastero and was kinda trying to finish the supplies. However, I've come to soldering the diodes on and i've got a bit stuck... How do you tell the polarity of a diode without building a tester circuit (I'm too lazy ) The diodes have a white band on one end, but no triangle markings indicating the flow of conventional (positive to negative) current. If someone can tell me what the band is (positive or negative), and if i'm on the right track, I'd be very greatful!
    Cheers
    Andrew
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
    pcman_cortina
    Guest
    the band/line is the cathode (negative)
    cheers
    pcman
    Dec 2001
    Paignton, Devon, UK
    Doh! Time to unsolder all the diodes i've just wired in the wrong way round...
    Cheers - I would have been able to look it up in my physics textbook, but we haven't been given them yet - the year above nicked most of them!
    Andrew
    Dec 2001
    Paignton, Devon, UK
    Just to confirm, does the black border round the solder point on the sproggy diagram represent the +'ve pin? I'm a bit confused about the mbr340 next to the big caps - am i right in thinking this is a reverse diode (thats what the R stands for)??
    Cheers
    Andrew
    Apr 2001
    Portland OR
    Think of the current flowing from plus to minus for a device that uses power. For a device that gives power, like a battery the current flows out of the plus into the minus. +--->|--- -
    A diode can only let the current flow from plus to minus, if you try to hook it up the other way current won't flow until the voltage gets really high. A zener diode lets current flow in the positive direction easily but has a breakdown voltage that is precise. So you use a zener diode backwards..
    Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Dec 2001
    Paignton, Devon, UK
    Cheers Jeff. Sorted.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Jun 2002
    Albany, NY
    Eehhh... Now time for a really dumbass follow-up to the really dumbass question
    I thought I had it all figured out *until* I read this thread, now I'm confused. So, on the Sproggy layout guide one hole for the mbr340 has a black circle, and the other does not. I put all the other diodes in with the anode facing the circled hole and the cathode facing the uncircled hole. This matches my interpretation of the schematic symbols which show the triangle pointing away from the circled hole. But for the mbr340, the triangle points towards the circled hole, so which should I follow, the symbol, or the circle?
    Dec 2001
    Paignton, Devon, UK
    Hehe the only diode i haven't done yet. This is kinda what was confusing me about this diode! Perhaps it is some funny reverse diode or something. Or maybe not ??
    Cheers
    Andrew
    Apr 2001
    Portland OR
    Andrew
    There is no such thing as a reverse diode. Look at the schematic, look at the datasheet. Don't look at some funky interpertation on the layout diagram.
    Jeff
    www.mpegbox.com
