Results 1 to 2 of 2
Thread: just a few questions:
    Jun 2002
    ok well i have just a few questions where can i purchase a 12volt power supply for my car puter?? also can some one post a few pix or sites of pix the some people r using for cases?? also what r some of u guys using as cables for signals ie 2 the lcd and mouse... thanx in advance for the info.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Some build their own power supply, sprogy or other. There are a couple available, I think pc power and cooling has one. Search/look through some of the older posts in this section to see. Some use off the shelf pc cases, some build cases. I built mu own from sheet steel and a lot of dremel cut off wheels . Here (not yet finished) are pics of the case and the console in my truck it will go in. http://www.imagestation.com/album/?id=4291925177 . I don't have any kind of display running yet and only a hacked off keybaord for input.
    There is really no wrong way to do it. If you can't build a p.s. or case buy one. If you can buid one build one. If you can build on but don't want to then buy one.
