Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: M2-ATX and LV-677 Mod Photos
  1. #11
    Feb 2006
    Melbourne, Australia
    Its a bit weak suggesting that the problem is with the motherboard!
    And it's a bit weak too that you suggest that the M2 is worse than anything else out there.
    Even today you will find new std AT X PSU's that;s not always 100% compatible with all components out there.
    It happens.
    I have tested my M2 on various boards, I have about 5 different setups here, and they all work - except for the timing mod I had to do on one cap to suit the Commell.
    So yeah.
    Just for the record, I have bith a Carnetix P1900 running my Macmini, and the M2 running my Commell board.
    So no fanboy, I just hate it when people thrash specific hardware when they have a problem with something small, and don't really know how to solve it, then blame the hardware
    Whatever you use, it's your prerogative anyway, so enjoy it. Just open your own thread if you want to bash M2, this is a mod how to make M2 compatible with LV-677, not how crap or good M2 is compared to other converters.
  2. #12
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    What is this timing issue?
  3. #13
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    WTF Mr_Bean!
    Do you design these things or get commision or something?
    A number of folk have posted up with M1 & M2 problems, they aren't perfect! FACT!!!
    The VIA EPIA SP13000 motherboard is made to adhere to the ATX power format, so if an ATX PSU will not work properly with the board, then the problem is with the PSU not the motherboard.
    You claim the problem is down to a cap, well fair enough... I'm not an electronics engineer, Im a Mechanical Engineer, so how do you expect someone with little or no circuit analysis skills to determine the cause of this problem???
    When I replaced my OPUS90 with the m2 I did so because I wanted some more Amps, no other reason. And I wish I hadn't! Thats all I said.
    The simple fact is that the Opus worked 100% and did what it says on the tin... The M2, has had various startup issues, it lets the PC drain the battery below what the car requires to start so it will leave you stranded if you aren't carefull. And yes the jumpers are set correctly.
    From what you have said above the problem seems to lie in the fact that the M2 cannot supply enough amps on the 5VSB rail, hows that a problem with my Mobo!?!
    And having to wait through about 8-9 boot cycles for it to do a clean boot is just plain crap! It ONLY works how it should when resuming from suspend, every other mode and it reboots.
    Odd days when its been freezing the PC won't respond at all, when before on the opus all was fine.
    OPUS every time for me, and I bet Im not the only member with that oppinion!
    You get what you paid for IMO, and I got what I paid for. I should have spent a few more beans on a proper PSU
    Go defend the M2 somewhere else
    EDIT: Some of my comments/quotes have been mixed up from this thread http://www.mp3car.com/vbulletin/powe...x-problem.html
  4. #14
    Feb 2006
    WTF Mr_Bean!
    Nope, I don't get commission, I didn't design the M2-ATX
    And I am
    Yep, that's why I am happy with both the Carnetix and the M2-ATX
    And hence why I feel happy defending the M2-ATX.
    Even here if I wanted to.
    My last reply wrt this matter, as I mentioned, it's your prerogative what you spend your money on, and what you ultimately use.
    I only say that is not fair you slandering specific hardware because there may be issues you are not aware of. And in the electronic's world, it is sometimes the case. If you don't enjoy these little expereinces, why then do carputers as a hobby in the 1st place?
    Have a nice evening, enjoy your setup.
    Regards.
  5. #15
    Aug 2004
    On the edge!
    I buy hardware that is made for the purpose, as I cannot make my own.
    When I buy something I expect it to do what it said on the tin, otherwise the item is not fit for purpose.
    If I pay for something I expect it to work, if I bodge something, I expect to have to fiddle to make it work.
    I don't however, expect to have to fiddle with something to make it do what it claims to do straight out of the box! And if there is issues with specific motherboards then the M2 team should make people aware of that before they purchase! And they don't!!!
    I wouldn't expect to have to start changing parts and soldering on an Opus, infact I've never even heard of such a mod being necessary on anything other than the M-series PSU's.
    I would be ****ed if I'd bought a VGA screen and then had to modify it to work with a VGA graphics card!
    I bought an ATX PSU, and as such expect it to work with an ATX motherboard. (I know the SP13000 is ITX, but it is ATX compliant!
    And its not like I use obscure hardware, loads of folk are using the SP13000
    Where are you coming from?!?!?!
  6. #16
    Feb 2006
    Quote Originally Posted by Crooper
    Is that with the current or older-version M2? Didn't they fix this issue?
    As far as I am aware, they have fixed this issue in the latest revision, mine was still previous version.
    Quote Originally Posted by Tom
    Please read my 1st post in this thread.
    Kind regards,
    MrBean.
  7. #17
    Aug 2004
    On the edge!
    And here's me thinking I have the 'fixed' v2 already
  8. #18
    Oct 2006
    Finland
    Is the version num of the M2-ATX readable anywhere on the circuitboard?
  9. #19
    Feb 2006
    Tom, I doubt it, mine is mounted, hidden away
    You can email them, but I am sure all new units from about 6 months ago were the ones with the fixed caps.
    Keep us posted as to your reply
  10. #20
    Aug 2004
    On the edge!
    will have a look at mine in a bit, not woke up properly yet, drank plenty of beer last night
