Results 21 to 30 of 38
Thread: M2-ATX and LV-677 Mod Photos
  1. #21
    May 2005
    Chico, CA
    After 2 dead M1-ATX and 1 dead M2-ATX (160w my ***...), I bought an Opus 150w and never looked back.
    I know how small these capacitors are. I tried to solder one on that was bumped off an A64 and solder to one for a VCORE mod. What a nitemare! Glad you guys found a fix, but send your results to mini-box and have them get everything sorted out. This isn't your problem and it's not worth it.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  2. #22
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Thank **** at least you agree this is a design fault
  3. #23
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Yes you can tell which version you have, I can't remember exactly how... search for it. It has to do with the number on a resistor or something. I checked it and mine's a new version (thank god).
  4. #24
    Aug 2004
    On the edge!
    where do we find out how to ID them then?
    There's a lot to search through on here RE: M2-ATX and I only get a 1/2hr lunch
  5. #25
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Quote Originally Posted by ShawJohn View Post
    I would be ****ed if I'd bought a VGA screen and then had to modify it to work with a VGA graphics card!
    PMSL that has to be my quote of the year so far
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
  6. #26
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    I have nowe gotten the computer working, I changed the harddrive to another (both SATA 2.5")
  7. #27
    Low Bitrate iselfdevi's Avatar
    Jul 2006
    NJ
    how does one test (or perhaps measure) one of these tiny caps? I have a multimeter but what setting do i put it on? These tiny things arent marked.
  8. #28
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Some multimeters can measure capacitance and that would be the easy way to measure it. The cheap (using an existing multimeter) and hard way would be to rig some some resistors, a voltage source and build a RC circuit. You would need to use a timer, find the time constant, and do some calculations.
    I noticed someone said this timing issue has been fixed with newer M2-ATX models. Will this newer model work with almost every standard motherboard or is there anything else that people need to look out for before buying?
  9. #29
    Jul 2006
    NJ
    Quote Originally Posted by nobb View Post
    What setting would i use on a multimeter?
  10. #30
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Look for some type of capacitance measurement symbol C.
