Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: M2-ATX and LV-677 Mod Photos
  1. #31
    Low Bitrate iselfdevi's Avatar
    Jul 2006
    damn. my craftman mm doesnt have it.
  2. #32
    Jul 2006
    Does anyone have any of these caps they could sell?
  3. #33
    Apr 2008
    i bought one of these feb 2008 to use with a commell mobo and it still has the timing issue , sorted my ***
    really annoyed 50 isnt that much but i could go buy a 550w psu for a home pc cheaper and it will work for years
    600 i have spent in a month on parts for a car pc and now i need to buy another psu
    dont think so ,out comes the soldering iron
    the instructions still have no reference to them not working on these boards ,they also dont state thaat the psu start up connector neeeds to be tested to determine which is + and which -
  4. #34
    Feb 2006
    Melbourne, Australia
    Maybe you should use logical thinking, no?
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  5. #35
    May 2008
    RE: Capacitor
    Where'd you get the capacitor?
  6. #36
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    Quote Originally Posted by iselfdevi View Post
    look back on prev posts some guy had to buy 200 of them, i bet he might just have one or two left over
  7. #37
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by eric_barcus View Post
    he paid a whopping $11AU for all 200 of them. so unless you're in AU, it would cost more to ship 1 then it would cost to buy 200 of them yourself from a local source
    he had to buy 200 of them because he wanted a surface mount version. you can go down to your local radio shack or other electronic parts store and buy a regular capacitor and use that instead. I would just buy a regular cap, bend the leads 90, carefully solder them to the board, then hot-glue it in place.
    good luck
  8. #38
    Low Bitrate FordNoMore's Avatar
    Oct 2007
    San Diego, CA
    Not sure if you're still looking, but www.newark.com sells these capacitors individually. Here is one example that sells for 3 cents each, but you can also just search for Ceramic Multi-Layer Capacitors, select 10nF, 0603 package (size), and pick one.
    Newark is a great place for all sort of electronics parts, and they have no minimum order.
