Results 1 to 10 of 10
Thread: Two battery Setup for carputer
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    If I connect two batteries but only want one connected to my cars electrical system when it is running, can I use an automotive 30amp relay as an isolator.
    Meaning, when the car is either in run position or in accessory the relay will switch on allowing the second battery to be charged from the alternator.
    My purpose is to prevent a dead battery. I want to hook up the carputer to my second battery so that when my car is off and if the computer hangs or continues to pull power from my battery I dont wake up to a flat battery that wont start my car.
    My second battery will preferably be a deep cycle marine battery.
    Help is appreciated.
    New Age Garmin - Skin for RR
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    There are two ways of doing this. One is with an isolator and the other is with a relay. Both have been discussed at length on this board.
    have a look here for a basic overview of the two setups. http://www.bcae1.com/battiso.htm
    If you search the forum, you will find heaps more info
    Aug 2006
    West Allis, WI
    I have searched the forums, but there is tons of blah blah blah I do not want to take the time to read through. I thought someone could just give me a simple yes or no.
    THanks
    Aug 2006
    West Allis, WI
    I do not wish to spend the cash for an isolator if a simple 30amp relay will work fine.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by ThunderStick View Post
    put your flame suite on. You will soon be bannished to the land of n00b.
    THanks
    Being computer people it is some proven thing that we do not try to waste our time with the trivial or with things already discussed. It has been proven through studies. So we usually do not give answers like this. We are a rude people.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2004
    NY
    a 30 amp relay will burn out... you will need a solinoid & big wires..
    when that battery is dead & you start the car that circuit will flow a lot of juice, most of what your alt can put out really, & even more, as the dead battery will also suck from the main...
    the best way is an isolator
    Aug 2006
    West Allis, WI
    Thanks for the input
    Damn that dancing skunk...He won't leave me alone
    Aug 2006
    West Allis, WI
    THanks again just bought a stinger sr200 isolator.
    Mar 2006
    BADGER!
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Not sure how reputable, but looks like good info
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  1. Powering car from a 13.8V power supply ok?
    By PURDooM in forum Power Supplies
    Last Post: 06-12-2006, 12:56 PM
  2. Replies: 1
    Last Post: 06-27-2005, 09:16 AM
  3. Will my setup cause a battery drain?
    By Skipjacks in forum Power Supplies
    Last Post: 12-13-2004, 02:09 PM
  4. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
