Results 1 to 4 of 4
Thread: is there anything wrong with this? (getting 3.3v)
    Jun 2002
    UK
    seams a much cheaper way of doing it than going down the switchmode route. plous i cant find anywhere to buy a max788 in the uk...and i have most of the bits for this. the only thing that really disipates any power is that tranny and ive got a fairly hefty one lying around...if not a bigger one is easily bought.
    what kinda current do i need on the 3.3v line?
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Check your MB manual and see how much it pulls. Mine only needs like 1.5A for a pIII and I am using a celery which is less so I just used a 5A linear regulator designed for 3.3v supplies. LM 1084-3.3 . I even have a MB that has an LM1084 on it (surface mount) for processors that need the 2.whatever voltage.
    Apr 2002
    South Coast, UK
    Re: is there anything wrong with this? (getting 3.3v)
    www.maxim-ic.com will send you free samples of that chip. Im not normally one to recommend you get freebies rather than paying for them, but Farnell dont stock that product code in the UK. Just fill out the form on the maxim site, and they forward to their european distribution, I got mine the next day!
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Jul 2000
    Israel
    This circuit is simply linear regulator. You don't have to build all this circuit,78XX series are working the same way.
