Results 1 to 8 of 8
Thread: new 8-18V to 12V 6A design : help needed
    Jul 2005
    Exclamation new 8-18V to 12V 6A design : help needed
    Hi,
    I am currently trying to design my homemade up to 10A 12V regulated car power supply based on a "miracle" national chip : the LM3478MM
    http://www.national.com/pf//LM/LM3478.html
    I have simulated with their online webench but some composant seems non adequate.
    Could I share this design to someone here willing to help please ?
    I have received 5 sample from this supplier and want to rapidly build a prototype capable of a mere 3A to begin with.
    Thanks in davance
    Registered User
    May 2003
    I didnt read the datasheet but I cant see that working as a 12V regulator. That chip will pass anything over 12v to its output, and as you know car battery voltage flactuates alot from 8V during cracking upto 14V during charging.
    Apply 14v to its input on the simulation and see what happen to the output.
    Jul 2005
    simulated with 8V in
    simulated with 17V in
    This is a switching device and time resolution is 10^-6 sec, that is 5Ás per division.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    You need boost/buck topology for output being in the middle of input range. Afaics this regulator is boost topology only.
    Jul 2005
    This chip is SEPIC capable, and this is what I wanna use.
    Am I wrong ?
    Here is the shematic...
    Apr 2000
    Bedfordshire, UK
    sepic is good. you didn't specify that, and the application circuit on the page you linked is not sepic.
    Jul 2005
    Oki, I dunno why it is not, so I've found this other shematic from an application note,
    is that better suited to what I want ?
    tks
    Jul 2005
    finally, I wonder if this
    http://www.trcelectronics.com/Meanwell/sd-50a-12.shtml
    would not be a better solution :
    cheap enough and 4.2A out vs 9-18V in but 72% efficiency means some heat to dissipate at high loads...
  1. Power suplie: 12v dc 250Wats 9v dc 18v dc
    By PORTUGAL in forum Power Supplies
    Last Post: 01-09-2004, 03:30 AM
  2. 120V to 12V adaptor how many amps needed?
    By nevide in forum Power Supplies
    Last Post: 12-23-2003, 08:46 AM
  3. Connect 3,5' hard drive in place of 2,5'' (dcdc for 12v needed)
    By FedorComander in forum Power Supplies
    Last Post: 11-04-2003, 08:16 AM
  4. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 01:33 PM
  5. How do I get 15V or 18V from 12V??
    By mp3commander in forum Power Supplies
    Last Post: 03-04-2002, 05:50 PM
