Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Modular Shutdown Controller with USB Interface
  1. #11
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Just having one negative trigger button that can handle car volts works for the door unlock or car alarm aux output as well as a normal button. Did that on mine, but I like knowing what triggered it too. The heartbeat is useful, but should be enabled by the software just in case you have to reinstall windows or something and the software side can't be run.
    I could tell you a lot about USB and standby. The computer may or may not keep USB power on depending on how it's configured so using that to determine if it's on can be a problem. Oh it also helps to have something to turn the monitor on/off, amp remote like you have and external USB power or other POL.
  2. #12
    FLAC evandude's Avatar
    Mar 2005
    Well, just a little update, I'm still quite active with this project, just haven't had much 'eye candy' to share, as I've been working entirely on the software/firmware side of things. Multi-threaded C# software communicating through a C++ DLL via USB to the SDC board, which runs firmware in C and (among many other things) communicates via I2C to the auxiliary board, which runs firmware in C (using a different C compiler, naturally), and handles the LCD. As you might imagine, it's been a headache, to say the least.
    But, things are coming along very well - I'll probably post up a screenshot of the current software soon, once I clean things up a bit.
    I'm definitely looking forward to diving back into the more fun and 'glamorous' hardware side of things, and will probably be throwing the main SDC board onto a PCB before long.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
  1. Alpine CHMs611 interface to usb mp3 (How?)
    By MrHackMan40 in forum Car Audio
    Last Post: 09-05-2006, 01:48 AM
  2. Please HELP!! PSU/ Shutdown controller questions
    By RJP350Z in forum Power Supplies
    Last Post: 12-23-2004, 03:37 PM
  3. Replies: 2
    Last Post: 12-05-2004, 02:51 AM
  4. High power PSU with shutdown controller
    By lookinco in forum Power Supplies
    Last Post: 08-25-2004, 01:00 AM
  5. Shutdown controller - New Version
    By weekendowel in forum Power Supplies
    Last Post: 06-10-2004, 01:28 AM
