http://www.mp3car.com/vbulletin/show...18&postcount=5
That post contains power calculators.
You will need to use the power calculators to determine how much power you will need for your system.
60 watts is pretty low power. I'd hope that you wouldn't be plugging anything else into your system. If possible, I'd go with a step-up on the PSU. The lilliput monitor requires regulated power. If the monitor has the egg on the power lead, then you can wire it directly into the car. If not, then you need to run it off of the PSU, which will increase your power requirements.
LinkBack URL
About LinkBacks
