Try Farnell
Paladin
neone have an extra?
"A4 Quattro. Rocket Science."
Hi,
instead of the MAX 787 you can also use a LT 1074 CT which is much easier to get.
You only need two additional resistors for the external divider because the LT 1074 is not fixed to 5V.
Works perfect!
cu
tsingsu
I gotta bunch, where are you located?
If in US I will drop one in an envelope to ya......
Tsingsu,
any ideas for the max788?
Paladin
@Paladin
Paladin,
I don't know about your electronics knowledge, but if you have a look at the website of Linear Technology you'll find some interesting information about regulators like the LT 1074, LT 1083 and others.
Maxim is not the only company which manufactures these kind of things, and the LT 10xx types (which are easy to get over here!) give you the possibility to replace the MAX 78x without any problem, even with an increase in power (the LT 1083 e. g. gives you up to 7,5A).
For the replacement of the MAX 788 you can also use the LT 1074; you need two additional resistors with a tolerance of 1% to set the output voltage as the LT 1074 doesn't have a fixed output voltage, but that is easy to do.
Look at the datasheet at
http://www.linear.com/prod/datasheet.html?datasheet=5
cu
tsingsu
Tsingsu,
Thanks for the info. I never heard of linear technology till now. All this while i've been trying to look for alternatives from motorola and national. from the datasheet it looks easy enough to add the extra components into the existing sproggy. But before i do that i'll have to see whether i can get the LT ics easily here in Malaysia. Else i'll be back to square one
Paladin
