Originally Posted by
2k1Toaster
Well the standard is mostly electronic jacks. I would guess it is a 2.1mm barrel connector. THe only difference usually is what the centre pin is. Ground or positive. And that leads me to my conclusion actually.
When you first wired it up, you probably forgot to check the polarity, and plugged it in. Since USB hubs have VERY LIMITED reverse current protection for the most part. Something went zzzzzap! So you switched the wires on the connector and tried again. So if the first round didn't kill it, then the second round probably did.
I would try with another hub. Since you have a radioshack by you I suggest borrowing one of their self powered ones. I used to work at a RadioShack, and I know what to do and such and I even know how to get the discounts and all. But all you need to do is buy it, use it, put it back the way you bought it and return it no questions asked for 30days. Even if you fry it, they will replace it. When they replace it, go to another radioshack and return it. That way you can test it out.
I know this is the not so good way of renting, but it is RadioShack. They pay their floor people minimum wage and charge a markup of usually over 400% for Radioshack brands. Less for other brands. So stick it to 'em!
Try the "borrowed" unit out but be careful to note the polraity needed by the connector. See if it works. If it does, hooray! And you can keep the one you bought. And if it doesn't work, return it.
