I think you need a stepdown DC-DC converter.
It is quite easy to build one, eg. LM2679 needs few external components.
You can use yor car voltage (regardless ignition, engine stops or runs) as a source. That converter chip does its part.
The simpliest method is to buy 2-3 7805 for 3A and wire them parallel, but it will produce anormous heat, so I do not recomend it, unless you are living in cold climate and can use as a heater, too![]()
The main problem is (also true for your diode-method) that you have to 'dissipate' the excess voltage at the same ampere, and it means heat.
LinkBack URL
About LinkBacks
