Results 1 to 7 of 7
Thread: PS Issues??
    Jan 2007
    PS Issues??
    Finally got everything together to put in and tried to do a quick test run before installing. After getting everything together I went to powerup system and startup no problem except I am not getting a video signal SO after playing with everything I could think of I found out that if I unplugged my DVD player and started up I would get a video signal but as soon as I plugged back in no video!!
    Replaced DVD player with 3 different ones with same results. Thought maybe the startup/shutdown controller was bad switched out with spare with same results. DC power is good cause I am running a regulated DC power with shop DC power supply
    Finally after hours of switching stuff back and forth and throwing stuff around and tons of cussing.
    Have OPUS 150 on the way to replace but was wondering if there was anything else I should check out.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    List all the items connected to the PS. My bet you are overloading the PS.
    Give full details on components... model #s if you can.
    TruckinMP3
    Read the FAQ!
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by TruckinMP3 View Post
    expecially if you are using the psu to power the screen. And what type of dvd player? I am guessing usb because you are hot plugging it.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    PS Issues??
    MOBO-EPIA-M1000
    DVD-Samsung SM-308 (Not what I am going to be using just using to test)
    HDD- WD80EB 80 Gig
    PS-PW-120A
    Start-up/Shut Down-unsure
    As far as the PS and stup/shdwn not 100% cause I bought it a while back; I have been piecing this together for some time.
    The screen is a Lilliput 8" TS; had that running off of the DC power supply
    I even took the Lilliput out and used my home monitor and still had the same problems.
    The DVD was not hot swapped had to shut down and repower to get it up and running.
    I am led to believe that the startup shutdown was causing a little of the problem cause I took a voltage measurement and I was only getting about 11.3VDC out even if I had the DC power supply putting out 14.4V like a normal car would. (I know I said I switched out the controller BUT I meant that I switched out the PS cause I had a spare.) Took out startup/shutdown and still had problems. Hope all that made sense!!!
    I know I sound like a noob and I am at the carputer stuff but do car audio and build home computers just never worked with all the DC-DC PS stuff!!!
    I live on this site and have learned tons of stuff just took a little time to get everything together before attempting. If this is something I could have found in a search I apologize but I coulnt find anything like this.
    Jun 2002
    Colorado
    How much RAM? Any other parts?
    The PW-120 does have a reputation for not really powering 120 watts.
    The trick is knowing what to look for. I think you are overworking that little PS.
    If you use a desktop supply will everything work?
    TruckinMP3
    Read the FAQ!
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    the PW-120 has only 60% effeciency, so that would mean it only puts out 72watts at most.....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Jan 2007
    out the door!!
    I knew it was to good to be true!! I wanted an opus 150 anyway just made the deal concrete when that one wouldnt support it. Have been piecing this unit together for 2 years now just didnt have the vehicle to put it in; but now that I am back in the US I went straight down and got my 03 Ram; hopefully the install will pick up after I get this PS.
    Have to get everything in before I go play in the sand in May.
    Thanks for all the help; I was about 85% sure that the PS was a POS but just wanted to run it through the pros!!!
  1. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
  2. Major system issues - please help!
    By Litespeed in forum General Hardware Discussion
    Last Post: 03-04-2004, 04:14 PM
  3. Arrrgh! Can't make up my mind about PS!
    By Pred8tr in forum Power Supplies
    Last Post: 01-27-2003, 12:22 PM
  4. Converting AT PS to ATX PS? How to?
    By Maveric in forum Power Supplies
    Last Post: 08-15-2001, 10:50 AM
  5. Arise ACE-865V dc-dc ps, system wont post, help...
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-17-2000, 03:08 AM
