Results 1 to 10 of 15
Thread: m2 atx problem
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Angry m2 atx problem
    Okay, i hooked up my m2 atx, j8 to the mb and j9 to a button, i also set the j10 to A (5/45). For some reason it wont send the signal to my MB to hibernate or boot. the m2 sends power to the MB after 5 or so seconds when i start my car and it also turns off after about 45 sec, but it wont boot like its supposed to. Any ideas?
    Elsewhere
    Do you have 12v running to your ACC terminal on the M2?
    Come to think of t, an overall idea of how it's wired might be useful, as well.
    How about the Wiki?
    Oct 2006
    Texas
    i have a 4ga wire running from my battery to a distro block in my dash that goes to the 12v+ on the m2, i also have it hooked up to the 12v+ acc wire that goes to my HU, then it is grounded to the chasis. Everything works fine it just doesnt send the signal to the mb to boot or hibernate...
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Do you have a continuity tester? Test the J8 pins for continuity as you apply the power to the accessory wire, and wait about 10 seconds. See if it closes.
    Does ANYTHING happen? What MB?
    Michael
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by david69leonard View Post
    If you push the buton manually? does it turn on? Both from the M2 and the motherboard.
    Basically short out the pins in the header on the mobo to turn on, and see if it goes. IF it works try to short out the header for the manual switch on the M2, and see what happens.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Texas
    i have a via 10000 mb, i havent tried using a continuity tester yet but i will as soon as i get home today. The button works just fine on both the m2 and the mb.
    Mar 2006
    This is going to sound stupid and go against most of what you know about on/off headers, but flip the header pin around. Fixes some boards. It did for mine.
    Right now if your M2's power wire is black and red, with pin 6 having the black, and pin 8 with the red, switch them, so that pin 6 has the red end of the wire, and pin8 has the black side. Leave it alone on the M2 side.
    The M2 works by either sending out a small infantessamle voltage or it grounds a pin. More than likely grounds. But if it is grounding a pin that on your motherboard does not point to ground, you get nada. Just try it.
    Oct 2006
    Texas
    hmmm... sounds interesting, i will try that when i take my lunch break here in about an hour or so, if its as simple as that ill prolly crap myself if it works...
    Mar 2006
    It isn't always, but it has been known to work. All depends on what your mobo is. I have a M10k too, so I know this works for this type of board. If it works, it just means the manufacturer went the cheap way of building the circuit rather the the full more expensive way. And by more expensive I mean fractions of a penny.
    Oct 2006
    Texas
    i guess over a couple thousand years, that fraction of a cent could buy the CEO of VIA a Big Mac and Coke... maybe even some fries...
    sorry im a little hungry, almost time for lunch
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 09:04 PM
  2. Problem m2 atx and 3.5" hard drive
    By Mitski's Rider in forum Power Supplies
    Last Post: 10-05-2006, 12:52 PM
  3. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  4. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
